Front end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Feb 2, 2015.
  1. Feb 2, 2015 at 7:19 AM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    The truck makes a noise from front end which occurs only one time when I start off from a location, another words once it happens I cannot replicate until the truck is turned off and sits for a while. When I go again after it has sat for a while it does it again. Occurs more when in a turn. The sound is hard to explain but a metal rubbing sound is as close to describing as I can get. Don't see any rub marks or parts that look worn out. Tia
