Front end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rnhrtfan, Mar 20, 2015.
  1. Apr 28, 2015 at 1:51 PM
    #61
    Rnhrtfan
    Rnhrtfan [OP] Well-Known Member
    WV
    06 Super White DCSB TRD Sport
    Cab mounts and other bolts that were not tight enough... will have to post specifics as soon as I know
  2. Apr 28, 2015 at 6:18 PM
    #62
    Rnhrtfan
    WV
    Put about 75 miles on the truck this evening... backed into every parking spot and driveway.... NO NOISE!!! SO FAR
  3. Apr 29, 2015 at 8:38 AM
    #63
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Wow nice!!
    I read into some torque specs and it looks like a lot of these items are really really low torque.
    An example is that the cross member to frame is 30ft lbs.
  4. Apr 30, 2015 at 3:04 AM
    #64
    Rnhrtfan
    WV
    Good news... have put about 200 miles on the truck and so far no noise... Bad news... front diff is now leaking around the right front axel... so.... back to the shop we go
  5. Apr 30, 2015 at 3:09 AM
    #65
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    x2
  6. Apr 30, 2015 at 7:34 AM
    #66
    Rnhrtfan
    WV
    No it is not the brake pads... this is not the same noise at all and it does not occur when applying the brakes... this noise is much louder and way more pronounced... more like a hammer to the frame rail... that's not an exageration... you can here the noise from across the parking lot at the dealership...
  7. May 3, 2015 at 3:37 PM
    #67
    wmsbgtaco
    wmsbgtaco New Member
    2005 Tacoma dblcab 4x4 off road
    thanks for all your research- i have an 05 that has recently begun making this noise and it's been driving me crazy- took it to the dealer and they recommended new upper and lower control arms- for $1500... not today... they did say they torqued the cab bolts but to no avail. I've been under it all day today- wheels off feeling the pop and thinking it's on the right- then the left- ahhhh- anyway- thanks again and any more specifics you have so I can pass that on to the dealer would be most appreciated!
  8. May 3, 2015 at 5:45 PM
    #68
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    My dealer did the pads and caliper pins under warranty. That fixed the brake pad noise. My creak in the front right when I back up, then turn forward with the wheel cut still remains!!
  9. May 4, 2015 at 10:45 AM
    #69
    Rnhrtfan
    WV
    no real earth shattering news yet... took the truck into the shop on Friday for the leaking differential... they had to order a right front drive shaft seal... they are installing that today... that should solve the leak issue I just hope the noise issue doesn't come back... we shall see...
  10. May 4, 2015 at 12:23 PM
    #70
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Thanks for the continual updates.
    I await the response of my local service dept. left them the VM saying the noise is still there on mine.
  11. May 4, 2015 at 12:32 PM
    #71
    Rnhrtfan
    WV
    WOW... just got a call from the dealership... new seal was installed and leak still exists... turns out new seal had a tear in it... ANOTHER new seal ordered today... so truck still isn't fixed...
  12. May 4, 2015 at 12:42 PM
    #72
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Sorry don't want to highjack your thread but did your "popping" sound like this?
    I've been having this clicking sounds for over a year now and haven't figured it out... Was thinking about taking it to the dealership for them to sort out.
    Seems to be coming from Left front wheel and happens when turning and general suspension activity (like speedbumps).
    It can also click multiple times like a quick tap dance, but mostly it will do it once then settle down until the next major hit.
    However, I can sometimes hit a large speed bump fast and it won't make the sound...
    Thanks!
  13. May 4, 2015 at 1:00 PM
    #73
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    I'm having that same exact noise from the drivers side front wheel area. This just started about 500 miles ago for me. Very noticeable when the wheel is turned all the way to the right and I'm going in reverse over a bumpy road.
  14. May 4, 2015 at 1:45 PM
    #74
    Rnhrtfan
    WV
    No... the noise I get is much louder and much more solid sounding... best way to describe it is get under your truck and give the frame a good tap with a hammer... sounds like something gets A LOT of tension on it the pops loose... you can feel it up through the floor board into your feet and ass...
  15. May 4, 2015 at 6:15 PM
    #75
    wmsbgtaco
    That is very similar to how mine sounds and when driving on less than smooth roads it happens a lot.
  16. May 5, 2015 at 1:40 AM
    #76
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have the same issue on my 12. I ruled out looseness in the suspension as I have checked every bolt and nut and am running aftermarket uppers and lowers. I ruled the sound out as normal. Eh. Ill find it one day. As of right now. Nothing worries me.
    Pictures of said area being loose and clunking?
  17. May 5, 2015 at 1:57 AM
    #77
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nice find! Oddly enough. I have a skid plate for the T case and the more I think about it. I get the feeling that those bolts may not be tight enough on it. I will have to check in the morning but that definitely gives me a good place to start as I have checked all the body cab mounts and the front suspensionis tight which leads me to have to check the area which can be prone to shifting. That cross member. The noise is fairly loud enough to the point where its annoying but I have almost stopped listening to it. Good tip. Thanks!
  18. May 5, 2015 at 3:53 AM
    #78
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Any chance that a loose bolt/nut is in the frame/rocker panel/fender/side step ??? IT appears that the "bump" needed to cause this is quite "Sharp" or sudden. Perhaps the loose item is hopping in its trapped location ...
  19. May 5, 2015 at 4:00 AM
    #79
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Heard back from Toyota. Scheduling the field service specialist from Toyota to make a trip up to see the truck.
  20. May 5, 2015 at 11:44 AM
    #80
    Rnhrtfan
    WV
    well if you were near WV we could just get them both taken care of at the same time... my noise appears to be gone but with the leaking axle seal i'm afraid the fix may have created another problem
