Front end popping noise that is NOT SUSPENSION RELATED?
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Dec 6, 2016.
  1. Dec 6, 2016 at 10:35 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    ALL,
    I have had this popping noise on my passenger front side for awhile. It happens when I start my truck... accelerate from a stop, slow down to a stop, when I roll over dips or pot holes and when I slowly make sharp turns in parking lots... it almost sounds like my front fender or bumper is loose or something. I just recently had my OME 881 and billys installed... I have read it could be the transmission mounts or body mounts as well.
    I am 100% sure. Has anyone had this issue? its driving me crazy. :annoyed:
    I have a 2000 Tacoma prerunner 2WD V6
  2. Dec 6, 2016 at 10:41 AM
    victorbravo
    victorbravo Member
    04 Tacoma 2.7 5 spd 4x4
    Poorly repaired body damage, etc.
    Do you have aftermarket skids? I had a phantom front end noise for months, turned out to be the transfer case contacting the skid plate.
    Other possibilities are sway bar end link bushings going bad, and worn out power steering rack bushings. These have both caused front end noise on my truck.
    I'd visually check your transmission mount before you order one, I replaced mine with OEM and the old one was totally fine. And it's not a cheap part. (Manual Trans)
    STEVEO13016[OP] likes this.
  3. Dec 6, 2016 at 10:49 AM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    mehbeh its the UCA's?
    I'm putting "new" (used) ones on this week to see if that's my problem. same sounds. clicking/popping from front end. I can post up when I'm done If I can find this thread.
  4. Dec 6, 2016 at 10:49 AM
    Wulf
    rock raisin
    I have a nearly identical issue and I think mine is play in my worn out steering rack
    STEVEO13016[OP] and Sicyota04 like this.
  5. Dec 6, 2016 at 11:25 AM
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    I would look inside the wheel well and see if you see anything hitting first or loose first.
  6. Dec 6, 2016 at 11:29 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I changed both CV axles, steering rack and both front wheel bearings and my mystery popping noise is gone!
  7. Dec 6, 2016 at 11:34 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Check the skid. Easiest check. Mine had the same problem, tightened it, and was good to go.
  8. Dec 6, 2016 at 1:03 PM
    eon_blue
    Azusa, CA
    Check your sway bar links
    jammer and DustStorm4x4 like this.
  9. Dec 6, 2016 at 1:11 PM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Same here....it was the source of the noise for me.
  10. Dec 6, 2016 at 2:17 PM
    STEVEO13016
    STEVEO
    thanks all for the responses. I will check to make sure my skid plate bolts are tight.... then I will check to see if the aftermarket sway bar links I installed about 2 years ago are going bad, then after that I will be sure to check the inside of the wheel well to make sure nothing is loose or outta place...
    I will update this thread once all this is completed.
  11. Dec 6, 2016 at 2:54 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Motor mount.
  12. Dec 6, 2016 at 3:35 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    ,,Or trans mount.
  13. Dec 6, 2016 at 3:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'll go with the sway bar, based on your occurrence description, even though you boldly proclaim it's not suspension related.
    Even if the links are still good, they may be binding. Depending on the style of link, it could be possible that cleaning and lubing would cure the issue.
  14. Dec 6, 2016 at 3:57 PM
    Tacoma 14
    Tacoma 14 dclb brm lb
    Va
    2014 tacoma
    I have a similar noise on my 96 4wd reg cab it started after i replaced the completely blown out struts
  15. Dec 6, 2016 at 4:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you torque the movable (pivot) locations to the proper torque, and was it with the suspension in full droop or loaded?
    Over torqued and/or torqued in droop will cause binding. If that's the problem, it won't be long till the rubber of the mounts are all torn up.
  16. Dec 6, 2016 at 5:02 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    Its most likely like the others said relateted to the sway bar. IMO with your new coils you probably wouldnt notice if you just threw your sway bar in the scrap pile.
    Only other thing i could think of is your UCA hitting the coils or binding.
    Just have someone drive circles slowly while you watch all the suspension and you should find it pretty quick.
  17. Dec 6, 2016 at 7:43 PM
    Tacoma 14
    Va
    2014 tacoma
    Hey bill no i did torque it. but I did it unloaded I can try braking it loose and tightening again i didn't think of that you may be spot on. thank you sir.
  18. Dec 6, 2016 at 7:54 PM
    tan-ishman
    San Diego,CA
    2005 DCSB
    Luckily mine have torn UCA boots so I'm thinking to start at the UCA's is a fair idea (160k)
  19. Dec 7, 2016 at 8:00 AM
    STEVEO13016
    STEVEO
    I went up under the truck this morning and noticed the right side sway bar link bushings are starting to tear... when I replaced my sway bar links I purchased a cheap brand from AutoZone... any recommendations on which kind of links to get?
    DustStorm4x4 likes this.
  20. Dec 7, 2016 at 8:06 AM
    jammer
    Ben
    Bentonville, AR
