Front end popping noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solution.45, Nov 2, 2019.
  1. Nov 2, 2019 at 2:25 PM
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    That sounds like a pretty awesome trip and hopefully all is good to go before you head out. I'm trying to go out on a 3 day excursion next week but I have major OCD and this noise is killing me man.
  2. Nov 2, 2019 at 2:26 PM
    Solution.45
    Chase
    Redding CA
    Yeah I know which one it is but thanks for looking out.:thumbsup:
  3. Nov 2, 2019 at 2:28 PM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    I wheeled for 7 hours last weekend in NH with it clunking every once and while, it was a big event I had to photograph so I just went with it and everything was fine. There is a trip coming up in NY 4 hours away that I may or may not decide to do if I can't figure it out. I'm more worried about the needle bearing and my tie rod end needs to get swapped because a branch caught the boot and ripped it.
  4. Nov 2, 2019 at 2:29 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I would check, in order:
    - LCA mounting bolt torque.
    - Lower uniball adapter bolt torque (different LT kits set this up different ways, I have had issues with this bolt coming loose and causing issues. I finally solved the issues by going to aircraft grade bolts and a castle nut with a retaining pin).
    - UCA mounting bolt torque.
    - UCA uniball to spindle bolt torque.
    - Inspect tie rods for play.
    - Inspect wheel bearings, ensure they are mounted tightly to the spindle.
    - Steering rack bushings/bolts (PITA to get at)
    JoshS, Rob MacRuger and tcjacado like this.
  5. Nov 2, 2019 at 2:35 PM
    Solution.45
    Chase
    Redding CA
    I've inspected everything except the LCA torque and the rack bushings but will be doing so tonight. Thanks for the input
  6. Nov 2, 2019 at 2:36 PM
    Solution.45
    Chase
    Redding CA
    I rip boots like they are going out of style. Was it an inner or outer boot?
  7. Nov 2, 2019 at 2:38 PM
    Hyland33
    Andrew
    Leicester, MA
    Outer fortunately
  8. Nov 2, 2019 at 2:39 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    My mistake, I couldn't remember the exact amount. I just remember having to go higher than factory. I might be thinking of the torque figures on my other vehicle. Popping noise definitely reminds me of the lower control arm bushings though.
  9. Nov 2, 2019 at 3:10 PM
    Mxpatriot
    Long travel games are fun, right?
    <-- will never DD a long travel truck again.
    MolonLabeTaco likes this.
  10. Nov 2, 2019 at 3:37 PM
    Solution.45
    Chase
    Redding CA
    SO MUCH FUN! :crapstorm:
    super_white likes this.
  11. Nov 2, 2019 at 5:49 PM
    Solution.45
    Chase
    Redding CA
    @JaCado @azzwethinkweiz @HAVOC @Hyland33 @Mxpatriot
    Thanks for all the input fellas, after getting home I found out what the issue was and it almost makes me mad to even mention it. The LCA bolts were not torqued to spec when aligned, they were torqued to 85 ft lbs when they should have been at 100. Something that simple has been driving me nuts for a week. Problem solved and definitely having a talk with the shop which did the alignment. Again thanks for all the input everyone!
  12. Nov 2, 2019 at 5:50 PM
    tcjacado
    tcjacado Well-Known Member
    Bingo:thumbsup:
  13. Nov 3, 2019 at 3:09 PM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    +follow for later
  14. Nov 3, 2019 at 3:19 PM
    Jburg
    Jburg New Member
    2013 off-road double cab short bed
    I’m having the same thing, I think I found a video on YouTube and it sounds exactly like mine. Guy started shaking his brake pads and they were clunking inside the calipers. I’m doing a full brake job this week on it at work. I’ll try to get back on here and give an update.
  15. Nov 3, 2019 at 8:00 PM
    #35
    Ross09
    Ross09 Well-Known Member
    Greeneville,TN
    2009 DCLB base 4x4
    Ive experienced the same issue off and on since I put a TRD pro suspension on my base model. It seems to only pop on the drive side when its either raining or cold outside and only when going over bumps or any amount of flexing is being done. Its been aligned, LCA bolts are good. IDK whats causing it.
  16. Nov 9, 2019 at 12:34 PM
    #36
    Jburg
    Jburg New Member
    Just did my rotors and pads, no more clunk sound.... worth a look if anyone has a similar issue. This has been driving me crazy......:oldglory:
  17. Nov 10, 2019 at 11:36 PM
    #37
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    im having the same exact issue with my icon suspension on the drivers side as well.
  18. Nov 15, 2019 at 4:00 PM
    #38
    Hyland33
    Andrew
    Leicester, MA
    I have that noise, the pads shift when you hit the brakes for the first time moving forward or backwards. The new clunk I’m having definitely seems suspension related. Happens at low speed when hitting a bump or hole. I checked some things real quick the other day and everything seemed tight. I have time this weekend to check everything else.
    93yotasr5 likes this.
  19. Nov 18, 2019 at 7:02 AM
    #39
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @HAVOC looking at that pic you posted, one of the bolts is labeled as toe adjustment.
    I always thought toe was adjusted with the tie rods.
  20. Nov 18, 2019 at 1:46 PM
    #40
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Strange. The lower control arm bolts adjust camber and caster. Don't know why they list it as toe. :confused:
    Larzzzz[QUOTED] likes this.
