Front end question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Burnett, Sep 27, 2016.
  1. Sep 27, 2016 at 1:59 PM
    Burnett
    Burnett [OP] Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    I've got a 98 Tacoma 4x4
    I just replaced steering rack bushings, inner and outer tie rods and lower ball joints. Had a four wheel alignment at Toyota dealer. The tech said he ran through the alignment three times but couldn't get the steering wheel to stay lined up. When you drive the truck straight, the steering wheel is turned to the left at the 10 o'clock position.
    Any ideas on what might cause this? The truck is aligned but this will no doubt bother the shit out of me.
    hour likes this.
  2. Sep 27, 2016 at 2:11 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Ask @lonzorizo
  3. Sep 27, 2016 at 2:13 PM
    CO_0321er
    CO_0321er Well-Known Member
    :popcorn:
    My 2nd gen does this too... they can't ever get it to sit strait
  4. Sep 27, 2016 at 2:22 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    My tech is always able to fix/adjust that. In addition did they charge you extra for all four? You cant adjust anything in the back is why i ask.
  5. Sep 27, 2016 at 2:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Are the tie rods set at close to equal lengths? Asking because we know those have been replaced recently. They won't be exact most likely, but should be close.
    Are the castor numbers equal for both sides? This is the typical issue. Bad castor.
    If tie rods are close and castor balanced..........
    Has the steering shaft been unhooked from the rack for repair or something?
    Has the steering wheel been off?
    4 wheel alignment? There's nothing on the rear to align.
  6. Sep 27, 2016 at 2:44 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Centre pin could have sheared and the axle might have shifted a bit. Not likely but Its happened before.
  7. Sep 27, 2016 at 3:04 PM
    Burnett
    Nolan
    North Georgia
    Ya I don't understand the four wheel alignment, like you said, nothing to adjust in the back.
    The outers were 21 turns each so they should be as close as they can get.
    Haven't had the steering wheel off.
    Haven't messed with steering shaft.
    Have to get the alignment sheet, I was in a hurry to get out of there and forgot all about it.
  8. Sep 27, 2016 at 3:40 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
