Front End Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ibengineer, Jun 16, 2010.
  1. Jun 16, 2010 at 8:16 PM
    ibengineer
    ibengineer [OP] Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
  2. Jun 16, 2010 at 10:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The bilsteins are adjustable. You use your stock coil. Basically, with the bilsteins - you can adjust the position of the lower coil seat. The higher the coil sits, the more lift (preload) you will get. Notice the threads on the shock body near the lower coil seat.
    http://www.fjcruiserforums.com/gallery/data/500/medium/bilstein_shocks_8_.jpg
    The OME setup is not adjustable. You can't change the position of the lower coil seat. You need to have a different coil spring with a higher spring rate to achieve the same amount of lift.
  3. Jun 16, 2010 at 10:38 PM
    ywen
    ywen Well-Known Member
    Are there any good write-ups for installing shocks and dealing with coil springs?
  4. Jun 16, 2010 at 11:18 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    to swap out the springs youll need a spring compressor that you can rent/buy at any auto store. the shocks are basically a direct replacement. one bolt on the bottom and three bolts up top
  5. Jun 17, 2010 at 3:26 AM
    ibengineer
    California
    00 Tacoma TRD 4x4
    so for me...buying some bil's and throwing in a spacer or something (to get a full 2.5-3) is way cheapear to get front lift than to buy ome c/o's? Then I would just need an AAL + rear shocks, and I could prolly fit some large 32's or small 33s?
  6. Jun 17, 2010 at 5:35 AM
    Janster
    Jandy
    Lancaster, PA
    Have you tried searching? There's plenty out there....seriously.
    The blue bar at the top right of this forum 'SEARCH' and www.google.com
  7. Jun 17, 2010 at 5:47 AM
    ywen
    Thanks! Will give that a shot and report back to ya
