Front end rebuild - Tone Ring Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by OlderIsBetter, Oct 24, 2024.
  1. Nov 4, 2024 at 5:49 AM
    OlderIsBetter
    OlderIsBetter [OP] Member
    1999 Tacoma SR5 V6 4x4
    The stock bushing measures 2.27" from washer to washer.
    The uninstalled energy suspension bushing measures 2.25".
    When pushed into a-arm it measures 2.31".
    When the sleeve is pressed in, it measures almost 2.38".
    No room for the other washer to press back onto the sleeve.
    I am thinking about buying 3 more OEM bushings and going that route. I will have to have an auto shop press them in and out.
    On a side note, the upper Energy Suspension bushings that came in the set fit perfectly.
    mic_standard likes this.
  2. Nov 4, 2024 at 6:21 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  3. Nov 4, 2024 at 6:29 PM
    OlderIsBetter
    mic_standard, zippsub9, leid and 2 others like this.
  4. Nov 4, 2024 at 6:46 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Good job OP. Trucks gonna be happy!
    OlderIsBetter[OP] likes this.
  5. Nov 4, 2024 at 6:50 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I might need to have you work on my taco!! Good work!!!!
  6. Nov 14, 2024 at 12:10 PM
    OlderIsBetter
    Hey guys, sorry I haven't posted in a while.
    I dropped my hubs off at an auto shop to have them do the pressing out and pressing in of the new bearings. I left them with the new replacement bearings, lock rings, brake plates and the seal pictured below.
    The shop just called me stating the seals were incorrect.
    I bought my parts online from Ourisman Toyota of Richmond.
    Their parts system shows these fit my truck, but the diagram does not look like a manual hub truck. I have attached a picture of the diagram.
    I believe I need the seal that is #9 on the diagram.
    I need to source the correct seals as soon as possible.
    Do any of you guys know the correct OEM part number of these seals?
  7. Nov 14, 2024 at 2:22 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Yeah, that diagram is a bit confusing to visualize but is correct. I press my own FWBs because the last shop pressed the bearing into the hub backwards. They failed in less than 2000 miles. Seal #8 for my '97 V6 Taco 4x4 with manual hubs is the 90316-69001 you show & seal #9 is 90312-95001: FRONT AXLE HUB | Toyota TACOMA VZN170L-CRMDKAB RZN161,171,VZN160,170 | Parts Catalogs | PartSouq.
    Ourisman: 1995-2007 Toyota Wheel Seal (Left, Right, Front) 90312-95001 | Ourisman Toyota of Richmond Online Parts. Check the p/n with your VIN to verify.
    Below is the OEM 90312-95001 seal installed on the knuckle before pressing the hub into the OEM/KOYO FWB with the correct bearing orientation:
    Chuckk321 likes this.
  8. Nov 15, 2024 at 11:26 AM
    OlderIsBetter
    Thank you!
    I found a good part number, but couldn't get a oem replacement that day, so I got an offbrand from O'Reilly. Dropped it off and it was right. Hope it lasts. The shop said they would be done today.
    leid[QUOTED] likes this.
