Front end shimmy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jnywadd, Nov 17, 2020.
  1. Nov 17, 2020 at 12:06 PM
    jnywadd
    jnywadd [OP] Member
    This is weird, when I tow something light like a jetski the truck feels like it shakes or shimmys just a little bit upon take off everytime. This is a brand new problem as the truck didnt used to do that, everything including the wheels are standard...its a 2005 Tacoma prerunner, anyone know what this problem could be?
  2. Nov 17, 2020 at 2:59 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have a carrier bearing, check that, then the driveshaft u-joints.
    06Tacooo and TnShooter like this.
  3. Nov 17, 2020 at 3:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree, the diveline angles can change when towing.
    That is one of the reasons you have a slip joint.
  4. Nov 18, 2020 at 1:52 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Simply put Tacomas stock rear springs are too soft so as soon as you put any weight on the rear as payload or towing the rear pinon angle changes relative to the trans/xfer angle as the springs wrap on take off. Many pots on site related to all this.
