front end shimmy
Discussion in 'Suspension' started by brutalguyracing, Jan 20, 2010.
  1. Jan 20, 2010 at 1:36 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    just had new wheels installed and balanced and there is still a shimmy at high speeds....
    is this shimmy from the lift ...5100's @ 2.5 & 2" aal
    i can feel it in the wheel and gas pedal...not in the seat or cab....
    any help would be great
  2. Jan 20, 2010 at 1:38 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Did ya get an alignment too?
  3. Jan 20, 2010 at 1:49 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    did you get new UCAs. i have a similar shimmy in the steering wheel over 65mph. i think it has something to do with the caster and/or toe noth being perfect
  4. Jan 20, 2010 at 4:08 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    what size tires? aftermarket uca's?
  5. Jan 20, 2010 at 5:25 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm still on stock ucas...deffinately the cause for in spec, but not great alignment numbers. 265/70/17 tires, so bigger, but not big. don't knwo abotu the op
  6. Jan 20, 2010 at 6:11 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i have stock uca and had an alingment done " not great but close " and stock 265/75/16
  7. Jan 20, 2010 at 6:16 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Worn tie rod ends maybe? :confused: If you jack the front end up and wiggle the tires right to left, and have excessive "play" that's probably what it is.
  8. Jan 20, 2010 at 6:20 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    cool i will have to check that out i did bounce off a curb a while back.... but had an alingment after
  9. Jan 21, 2010 at 1:25 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    might have to do a front diff drop or carrier bearing drop...they sell kits for this to help...also shims under the leaf springs can help...i've heard of others having this problem but it can be fixed most of the time
    look here:
  10. Jan 21, 2010 at 5:05 AM
    TacoSupreem
    Hayden
    Kentucky
    Yeah try the carrier bearing drop and axle shims that go under the rear leaf springs to help correct pinion angle.
    U can get them at toyteclifts.com
