Front end squeak
Discussion in 'Suspension' started by mxmaniac, Oct 16, 2009.
  1. Oct 16, 2009 at 4:19 PM
    mxmaniac
    mxmaniac [OP] Member
    Tyler
    chino hills
    05 PreRunner
    Donahoe coil overs (set at 1") ,Camberg spindles, Camberg UCA, OME Dakar leaf pack, Bilstein 5100.
    i Know people ask this alot but i cant get rid of my squeak. I just greased everything in the front end and i spayed my UCA with the dry teflon lube and it still squeaks. It squeaks when im just driving straight, when i turn, when i hit a bump, i mean alll the time. Is there something im missing?
    Thanks for your help.
  2. Nov 12, 2009 at 5:51 AM
    johnnief
    johnnief Active Member
    Johnnie
    L.A.--Lower Arkansas
    2012 TRD SPORT 4x4
    My truck did the same thing. I tracked mine down to the upper control arm bushings. What I did was get a needle that you put on the end of a grease gun and poked through that bushing and squirted grease in it until it ran out the side of the bushing. It will only put a small hole in the bushing that will close up when you take the needle out. The squeak may not stop immediately but give it a couple of days to work itself in and it should stop.
  3. Nov 12, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If they are TC arms, or similar, I have found they are not being greased propperly uppon instalation. The bushings need to have grease rubbed all over them before being installed onto the UCA. Then, about 4 pumps of grease every other day for a week.
    Benny123 likes this.
  4. Nov 12, 2009 at 6:43 AM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    I've got a squeak too, but I'm almost positive its coming from my lower control arms near the crossmember mount.
  5. Nov 12, 2009 at 1:32 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    maybe the u joint in that pre runner
  6. Nov 12, 2009 at 4:22 PM
    mxmaniac
    Tyler
    chino hills
    05 PreRunner
    I think ill try sticking a needle in there so i can grease it. i took my truck to a dealership for a 65K services and they tightened all my bolts but now my rear squeaks like crazy its coming from the bushings ill try doing the same there to.
  7. Nov 13, 2009 at 10:15 AM
    johnnief
    Johnnie
    2012 TRD SPORT 4x4
    My rear was squeaking too and I thought it was coming from the bushings there too but it wasn't. When I got to looking closer I found that it was coming from between the top and middle leaf springs. I was able to spread the springs apart with a screw driver a put some thin sheets of rubber between them. If its not the bushing in the back try this next. Put the sheets at the end of the springs on each side where those thin factory plastic pads are at. Make sure you clean out any dirt or mud that may be between them. I just did this yesterday so I dont know how long that rubber will last. Hopefully for a long time.
  8. Nov 13, 2009 at 10:48 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    ide say that rubber wont last to long with all the friction between those springs.temp. fix imo.
  9. Nov 13, 2009 at 11:10 AM
    johnnief
    Johnnie
    2012 TRD SPORT 4x4
    yeah i dont think it will last long but it was a quick and easy fix.
  10. Mar 23, 2010 at 10:33 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Mine squeak pretty bad. I have a J&D LT kit which seems very similar to TC's UCA. I only do about 1 pump which makes the grease shoot out the washer like side of the bushing. Should I consider trying a few more pumps and wipe off the extra? About how long do they last?
  11. Mar 23, 2010 at 10:36 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Do what I did and sell them and buy Icons ucas. Problem solved! The squeaking nearly drove me insane! (serious!!!)
  12. Mar 24, 2010 at 12:33 AM
    MadTaco461
    CA
    Kinda stock
    Lol, Only if it is that easy! Icon doesn't make one for my truck :mad:. Until I do race travel so they can be uniballs instead of bushings.
  13. Mar 24, 2010 at 7:38 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    post up some pics of your truck man! it looks bad ass in your avatar.
  14. Mar 25, 2010 at 8:35 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    http://www.youtube.com/watch?v=8BTAB0-MSIQ
    I still need to get the pics online but here is a vid. I took her over some whoops last week and did a vid so I can figure out what valving I need to do for the front and rear.
  15. Mar 25, 2010 at 8:36 AM
    MadTaco461
    CA
    Kinda stock
    That's my post up there. I was signed in while not knowing under my bro's profile.
