Front End Squeak!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tyler Andrews, May 31, 2021.
  1. Aug 2, 2021 at 7:37 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I’ve used the Scotty Killer suggestion of AT-205 in a squirt bottle. I had some squeaking about 5 years ago. It rejuvenates rubber with no petroleum distillates. It’s not a lubricant but a conditioner. Been spraying all bushings and cv boots about 2x a year and it’s never squeaked since. I have 166K miles and almost 12 years old.
  2. Aug 2, 2021 at 8:24 PM
    Preston0211
    Preston0211 Member
    Preston
    21 MGM Tacoma
    Fuel Ammo anthracite wheels
    I have a short video but can’t figure out how to post it on here
  3. Aug 2, 2021 at 8:31 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Post it to you tube and link to here
  4. Aug 2, 2021 at 8:33 PM
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    I had a similar squeak from my front driver side.
    Beaverton Toyota looked it over. Told me it was my aftermarket suspension and noisy tires. Told me everything looked fine.
    So, I took the wheels off and closely inspected everything myself. It ended up being a dry UCA ball joint. I found a tiny tear in the boot. It'd lost grease. Took it apart and it was full of grime. The ball joint was all loose. Replaced it and squeak went away.
  5. Aug 2, 2021 at 8:36 PM
    Preston0211
    Preston0211 Member
    Preston
    21 MGM Tacoma
    jsev and Steves104x4[QUOTED] like this.
  6. Aug 3, 2021 at 3:59 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
  7. Aug 5, 2021 at 4:49 PM
    TheCochese
    I attempted to change out my front bushing, but didn't have enough room to fit my crowbar in. Put the OEM one back as it wasn't damaged to my eye, and torqued it back up. It fixed the noise.
    Something to consider if you don't have a ton of miles.
  8. Aug 8, 2021 at 8:54 AM
    Preston0211
    Preston0211 Member
    Preston
    21 MGM Tacoma
    Update: took it in for the 5k service on Friday and told them about the squeak and showed the advisor the video I took of it. Of course it wasn’t squeaking when I took it in. The whole tech drove it in a parking lot over speed bumps and couldn’t hear anything so nothing was done. And according to my service advisor the 2” leveling kit won’t affect factory warranty, so there’s that.
    71tattooguy likes this.
  9. Aug 8, 2021 at 9:00 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Similar noise over here as well. Not worrying about it. The what if’s will kill you. Until something grinds or falls out. No worries :rasta:
  10. Aug 27, 2021 at 3:33 PM
    Preston0211
    Preston0211 Member
    Preston
    21 MGM Tacoma
    Update: Took it to a different dealer today and they called me and said they found the source of the squeak. Said it’s the passenger side body mount. Apparently it was bad enough that they get get a screwdriver in it. Parts won’t be in until tomorrow
  11. Dec 1, 2021 at 8:29 AM
    TacoJase
    TacoJase New Member
    My ‘21 TRD Sport is currently in the dealer for the same exact issue / sound as in the first video. They’ve replaced the cab mount bushing already, and that was only after they couldn’t replicate the sound but I was instantly able to do it when picking it up. Once again they haven’t been able to replicate the sound, although I have video and it’s the same sound as the first time it was in. My truck has been doing it since day 1. I just hope they can fix it.
  12. Dec 1, 2021 at 8:48 AM
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Exact same issue here before and after 5100s lift. If I rock the truck from side to side pushing on the passenger side above the front wheel well I can get it to sing sometimes. The shop that did my lift suspects its a pinch weld around the radiator on the passenger side, but not certain.
  13. Dec 1, 2021 at 9:04 AM
    TacoJase
    TacoJase New Member
    i can get it to creeaaak just by stepping (even lightly with one foot) on the driver side running board. If two different cab mounts result in the same thing (factory and replacement), I tend to think it may be something else. Even if it isn’t making the sound, a few seconds of rocking makes it come right out. I can see on my Toyota app that they have just driven it around and then said no replication. Wonder if they hopped on the boards this time.
  14. Jun 22, 2022 at 11:01 AM
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    Mines doing the same. Eibach coil upgrades possibly have an impact? Only 1.25" increase.
  15. Aug 20, 2022 at 9:05 AM
    #35
    FirstToy
    FirstToy New Member
    2018 Tacoma Off Road
    Thanks for the great suggestions! I always start simple and go up the ladder…
    The front end of my 2018 with 18,000 started squeaking like crazy. Took the easy path and sprayed Tri-Flow on every bushing/joint in the front end, including the tops of the coil springs.
    It was immediately as quiet as a mouse….
    Small price to pay for the 5 minutes this took me to do it. I might just do it every oil change since I am under there anyway!
  16. Aug 20, 2022 at 9:16 AM
    #36
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    I had both of the front mounts on my 2021 replace at 8000 miles. Curious to see how long this 2nd set last
  17. Nov 6, 2022 at 9:55 AM
    #37
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    This has been my issue for a year or two now.
    Need to get my shocks rebuilt and this bearing replaced, but until then I hit it with WD-40 every two weeks or so.
  18. Nov 9, 2022 at 1:59 AM
    #38
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    Mine did that and it turned out to be the front body mounts by the bumper. I had them replaced at toyota under warranty and the noise went away
    PzTank likes this.
  19. Dec 4, 2022 at 4:25 PM
    #39
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Climbed under my truck today and had someone rock it for me…..the squeaking now (very loud) is coming from my LCA’s. I’m going to try and hit it with some silicon lube and see if it helps.
  20. Dec 5, 2022 at 3:12 AM
    #40
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I also have had the same noise. I generally start at the top, UCA bushings and work my way down. With the truck on its static weight loosen the UCA, and LCA bolts to re-grease, then torque the bolts down. As for the lower bearings, there is an issue with the factory bolt that Toyota uses as it has a tapered section causing the misalignment spacers to not sit unevenly. The front facing spacer is on the thinner part of the bolt, it will cause front end noise over time. Around 4 minutes into the video I explain the bolt issue.
    https://youtu.be/8NNCR5E10-8
