Front end squeaks like crazy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by medicfung, Dec 12, 2022.
  1. Dec 12, 2022 at 3:35 PM
    medicfung
    medicfung [OP] Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    Hey guys, im running king 2.5s with resis and adjusters, camburg uni UCAs, icon RXT leafs, and wheelers bump stops all around. I still have the sway bar on, and im raised in the front by a couple inches via pre load on the kings and 600lb springs. Theres also a c4 hybrid bumper, winch and lights to weigh it down. My question is my front end squeaks like crazy. It’s all been open there for less than 30k miles, and started to squeak recently. When i turn the wheel it squeaks and a little on compression and decompression.
    Where is this coming from and how do I fix it? From what i can hear, it sounds like its the bushing that hold this sway bar?
  2. Dec 12, 2022 at 3:43 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
  3. Dec 12, 2022 at 3:56 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Turn your music up :headbang:
    ToyoTaco25 likes this.
  4. Dec 12, 2022 at 4:00 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Get a helper to turn the wheel/bounce the truck while you investigate under there.
    Use your head - don't stick your fingers anywhere they will get pinched.
    You should be able to feel the squeak with your hand on the offending part. If it is a bushing you can spray some silicone on the suspect area - the squeak should go away almost instantly, don't worry though, it will come right back. :laugh:
    wilcam47 and medicfung[OP] like this.
  5. Dec 12, 2022 at 4:05 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I had an issue recently and while I never figure out why I stopped the squeaking by disconnecting the UCA from the spindle, cleaning and putting it back together. Something must have gotten in between there causing it to squeak.
    I’ve got SPC uppers but that does not mean yours UCAs can’t squeak at the same place.
  6. Dec 12, 2022 at 4:11 PM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    my money is on the lower shock eyelet spherical bearings. if you rock the truck back and forth and they squeak to the movement there is a good chance its that. replace with COM10T.
    medicfung[OP] likes this.
  7. Dec 12, 2022 at 6:37 PM
    medicfung
    richie
    I guess I have a lot more investigating to do, lol. Thanks for the suggestions fellas
    RustyGreen likes this.
  8. Dec 12, 2022 at 6:44 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Let us know what you find. Hopefully nothing expensive. :fingerscrossed:
  9. Dec 12, 2022 at 6:45 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    :spy:
    medicfung[QUOTED][OP] likes this.
  10. Dec 12, 2022 at 7:28 PM
    medicfung
    richie
    Replacing all the bushings and ball joint to the x joint on my camburg UCAs so its already $400 in the hole lol
  11. Dec 13, 2022 at 2:56 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    For me its usually the UCA bushings, wipe them down, loosen the bolt, re-grease and torque with the truck sitting on it's own weight. 85lbs Do the same thing for the LCA bolts. 105lbs(usually go a tad bit more on these than whats called for) I try to do this at least once every 4-5 months, your environment will have a roll in how often it needs to get re-greased.
    Also, as mentioned before your mis-alignment spacers in the lower spherical bearings could also be causing the squeaks.
    Here is a video replacing the lower bearings.
    https://youtu.be/8NNCR5E10-8
  12. Dec 13, 2022 at 6:17 AM
    medicfung
    richie
    Thank you! I’ll check into this too
    ClassyTacos[QUOTED] likes this.
  13. May 23, 2023 at 10:21 AM
    medicfung
    richie
    Update!
    Ok, so had my buddy @GHOST SHIP tear into my front end and rid me of the squeaks. Turns out my UCAs needed a rebuild, the bushings were all worn out and there was a little play in the uniballs. While there, he also took out my coil overs to confirm the lower spherical bearings were completely shot. To the point that the sleeves were elliptical and let the ball just fall out. So, ordered new uniballs, UCA rebuild kit, and stainless steel spherical bearing kit. Squeaks are gone and front end is happy running smoothly thru its travel.
    GHOST SHIP and Zuba Gooding Jr like this.
