Front end squeek driving me crazy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBurrito01, Jul 6, 2019.
  1. Jul 6, 2019 at 5:37 AM
    TacoBurrito01
    TacoBurrito01 [OP] Active Member
    Listowel
    08 DCLB Sport
    My front end has been getting more and more squeeky as time goes on. It's starting to drive me crazy. It used to be just from time to time but now it's almost constant. I spend a lot of time driving across farmers fields and corn stubble at slow speeds so I'm sure you can imagine how annoying this squeek is getting. My strut retainer cushion thing certainly doesn't look right.
    In these videos all I'm doing is hitting the side of the tire to make the noise.
    Any ideas?
    https://youtu.be/iGG60AubFI0
    https://youtu.be/UlY01YTXhic
  2. Jul 6, 2019 at 5:50 AM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Brake dust shield?
    TacoBurrito01[OP] likes this.
  3. Jul 6, 2019 at 7:53 AM
    TacoBurrito01
    Listowel
    08 DCLB Sport
    Good suggestion. I hopped back under there to see if it was coming from the dust shield... It's not though. Seems like it's coming from the top of the shock somewhere.
  4. Jul 6, 2019 at 7:59 AM
    Jrod0506
    Jrod0506 Active Member
    2017 Toyota Tacoma trd sport
    Have you tried to spray all the dirt and mud off ?
  5. Jul 6, 2019 at 8:07 AM
    TacoBurrito01
    Listowel
    08 DCLB Sport
    A month or so ago I tried that with no success. Worth trying again I suppose
  6. Jul 6, 2019 at 8:12 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Look like you might want to replace the top hat and bushings on your shocks.
    If that doesn't solve the squeaking, at least you've performed some (apparently) needed maintenance.
    You can also go through and spray some silicone lube or something one by one on each joint/bushing/bearing until it goes away. Once the squeaking goes away, you know which one to work on or replace.
  7. Jul 6, 2019 at 8:12 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Is it just me, or does it look like your shock is shot? The top of the shock top should be in the center of the three bolts on the top and it looks like it is off by about an inch. I know you have a spacer lift, could that be the problem? Extra wear and tear on the shock due to the spacer?
    TacoBurrito01[OP] and DarthPow like this.
  8. Jul 6, 2019 at 10:21 AM
    TacoBurrito01
    Listowel
    08 DCLB Sport
    All great suggestions thanks.
    I only bought this truck back in February. I'm embarrassed to admit that I didn't even know this truck had a spacer lift. With my current living situation and lack of space and tools I may just take her in and get someone with the right tools and know-how to get the suspension right again.
    DarthPow[QUOTED] likes this.
  9. Jul 6, 2019 at 9:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You need to apply a force to what ever part or parts that are causing the squeaking.
    I’ve used a large blunt flat screw driver with success by prying on different parts and places.
    Obviously you don’t want cause damage to any parts. Take it easy. Eventually you’ll find the correct part by hearing a change in the squeak.
    I’d start near or at the parts with bushing first.
    Having some one to shake the truck and assist is a lot of help.
    Hope you find the problem. Noises can be very annoying.
  10. Jul 7, 2019 at 4:17 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I used to have to grease the hood latch on my old T-100 every couple of months to stop an annoying squeak.
    rollin904 likes this.
  11. Jul 7, 2019 at 4:18 PM
    Jrod0506
    What’s the best lube/ grease that I should be using ?
  12. Jul 7, 2019 at 4:20 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    looks like u need some new struts and coil spring bushings homie
    TacoBurrito01[OP] and TomTwo like this.
  13. Jul 7, 2019 at 4:21 PM
    BillsSR5
    bill
    2014 SR5
    I use silicon spray cause it doesn't attract dirt
  14. Jul 7, 2019 at 5:31 PM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Matches my leaf spring squeaks... Sorry, I know, that's no help. Annoying for sure.:anonymous:
  15. Jul 7, 2019 at 5:33 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Mine was coming from my hood latch, grease will fix it
  16. Jul 7, 2019 at 5:55 PM
    TacoBurrito01
    Listowel
    08 DCLB Sport
    I think you're right. Passanger side doesn't look much better.
