Front End Swap: 98-00 to a 95-97
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Dec 22, 2013.
  1. May 8, 2020 at 5:44 AM
    #41
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    FYI, using the old plastic headlight buckets worked relatively well. You end up having a lot of trimming to get to fit. I used a set of aftermarket adjustment screws (eBay- came from Thailand) and inserts. I suspect I will replace them with an OEM set - kinda cheap, but for short term should do. Longer adjustment screws would be nice,
    I used a set of used headlight brackets and rings and two springs on the bottom- outer spring pulling down, inner pulling up. You remove the round knob bolts that the plastic headlight snaps onto, and some m6 x1.2? bolts threaded in from the backside , a screw mount made out of about 2-1/2” piece of plumber’s tap folded in half, a serrated locknut to secure it. (If you have better quality PT a single piece might do, just doubled it in case)
    I was thinking about trying to mimic the Uber sharp paint job you did on yours-looks awesome! But by some odd quirk of fate- my replacement grill, silver/black and the corner lights all matched, it doesn’t look to bad. I need to get some of the plastic inserts that the out mounting screws would use to hold the corner lights into the fender, but it looks good with just zip ties right now. Plus the secret is to hide it behind an ARB bull bumper!
    #41
  2. May 8, 2020 at 7:22 AM
    #42
    Loctite77
    Loctite77 Well-Known Member
    Zeek
    NC
    2097 mashup vroom vroom bigwheelieee
    Some rust, runs good.
    That looks good man! I’m working on this same headlight swap now, taking a slightly different route. I’ll post photos soon.
    #42
  3. May 8, 2020 at 8:50 AM
    #43
    Arctic Taco
    Denali Park, Alaska
    Thanks, I still need to aim the lights some but I think it works. Might be a bit out of level, but since the front frame horn (pass side) are a bit tweaked, it adds to the character...
  4. May 8, 2020 at 7:13 PM
    #44
    Loctite77
    Zeek
    NC
    Here is my solution for 97 headlamps and grill on a 2000. 1/2” tubing with some nuts and generic headlight bolts. Haven’t mounted springs yet but any mid 80s GM spring should work.
  5. Sep 21, 2020 at 2:24 PM
    #45
    97tacoma
    97tacoma Active Member
    97 tacoma sx 4x4
    Did you need a 96 hood or are the hoods the same?
  6. Sep 22, 2020 at 6:25 PM
    #46
    Loctite77
    Zeek
    NC
    Hoods are the same.
  7. Sep 22, 2020 at 6:28 PM
    #47
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Got a 98 black hood for sale if anyone is interested
    1997tacomav6 likes this.
  8. Sep 22, 2020 at 7:11 PM
    #48
    yodataco23
    yodataco23 Active Member
    98 tacoma 2.4l 2WD
    how much? I have a red 98 Tacoma with sunfaded paint. might look dumb with a black hood but could be interested
  9. Sep 22, 2020 at 9:10 PM
    #49
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  10. Nov 27, 2021 at 6:08 PM
    #50
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    If I were to do again I would. But drilling out the 98-00 support and welding in the 95-97 support perfectly comes with its own challenges.
    For my swap we just ended up using the 98-00 support and adjusting the headlight holes accordingly to accept the 95-97 headlight mounting brackets and adjuster screws.
  11. Dec 3, 2021 at 4:07 PM
    #51
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just take them off of a junked vehicle
  12. Dec 3, 2021 at 8:03 PM
    #52
    Madjik_Man
    Honestly I do not know for sure. I know guys have done the swap far less involved than the one we did.
    What it comes down to is if you can securely mount the headlight assemblies and adjust them.
    But like Dalandser said above, there's always part outs. That's where I got my retainer rings and mounting brackets.
    Tacoboy1[QUOTED] and Dalandser like this.
  13. Dec 4, 2021 at 6:19 AM
    #53
    Madjik_Man
    yes those are the mounting brackets
  14. Dec 11, 2021 at 1:24 PM
    #54
    Tacoboy1
    Tacoboy1 Well-Known Member
    Nathan
    Southern California
    2000 Tacoma 92k miles
    Is this the screw to take out the headlight assembles?
  15. Dec 11, 2021 at 8:07 PM
    #55
    Madjik_Man
    Wow, maybe?
    I can’t remember. I know on the 98-00 there was a large gray plastic mounting piece. I seem to remember just removing that whole thing and the headlights.
    I didn’t watch this video but it seems like it would help you:
    https://youtu.be/12UT7uGvIYM
