front end too high
Discussion in 'Suspension' started by lazymf, Jun 10, 2012.
  1. Jun 10, 2012 at 10:12 PM
    lazymf
    lazymf [OP] New Member
    Canada
    01 TRD Crewcab
    I just finished installing the toytec Ultimate lift along with aal and 1 inch shackle at the back. I just realize that the front end is sitting too high. My front end is extra 2 inches high than the rear (front sitting at 25" and rear sitting 23inches, I measured them from centre of the hub to the bottom of the fender fare). The front was measured at 22 1/2-3/4 to start off, I don't rmb what was the stock high at the rear, but I don't know why the rear end is sitting so low.... Any help/advises/suggestions??? PS it's a 2001 crew cab. ( it sit taller at the rear before i install the lift)
  2. Jun 10, 2012 at 10:16 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    can you adjust the front coilovers? i thought you could with that kit...
  3. Jun 11, 2012 at 8:04 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Lower the front! My "pre-set" height was 4"+ and rode like ass! Lower them to 22.5-23" and you'll be set!
  4. Jun 11, 2012 at 12:32 PM
    lazymf
    Canada
    01 TRD Crewcab
    alright, i would give it a try. But i was wondering if it's my rear leaf being too old and possibly dead. I know the toytec is pre-set at 2.5 inches and shouldn't my rear end be level by adding the aal and 1 inch shackle? any thought?
    PS anyone one know how to adjust the height on bilstein 5100???
  5. Jun 11, 2012 at 12:33 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    bro lean! lol
  6. Jun 11, 2012 at 12:45 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    On the 5100 you need to change the spring seat location to change the height.
  7. Jun 11, 2012 at 4:18 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    If you have the ULT kit, it has adjustable collars at the bottom! Use the spanner wrenchs to lower the height! The 5100's are installed at the 0 setting by Toytec!
  8. Jun 11, 2012 at 4:44 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    That is a bit, odd... You got 2 1/2 to 3/4" lift in the front? That seems about right.... :notsure: I'd say wait about a week before you do anything to see if the front end will settle a bit. But if it doesn't maybe the stock leaf packs are pretty tired out. :eek: How miles are on the truck?
    Keep in mind that if you're going for a level truck, the front measurement (hub to fender) is actually going to be larger than the rear measurement because the front fender goes up higher than the rear. (I don't know exactly how much though... sorry.) If you haven't taken that into consideration, than you might want to take measurements from your frame to see if it's level... :notsure: Got a picture of the truck and the suspension components?
  9. Jun 15, 2012 at 12:59 AM
    lazymf
    Canada
    01 TRD Crewcab
    Thanks guys...I am gonna take everyone's advise and drive it for a bit and see. it has 200,000km on it and everything were stock until last week. It seems like my front seattle a little, but still a bit on the high side. I haven't got a chance to actually measure it, but no excuses ... hahahaha
  10. Jun 22, 2012 at 7:36 PM
    lazymf
    Canada
    01 TRD Crewcab
    Alright, it's been after a week or so....my front end settle a bit and the rear seems to rises a little... still not level but acceptable... HOWEVER, I drove my truck to a locate 4x4 shop, which they say my rear leaf pack is pretty much done. my AAL is supporting the rest so the old Leafs are sad and the AAL is happy there's a cap between them.... they advise me to replace my leaf pack with OME, but another shop is telling me they could fix it by adding a longer leaf n bent the old leaf to the original spec....this is the question...
    -New leaf pack + installed $777
    -Old leaf pack renewal $550
    Which one should I go with..?????
  11. Jun 22, 2012 at 8:25 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    You need to check with member on here, 4wd he can lead you in the right direction.
