Front End Vibration Despite New Pads and Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoturd913, Jan 28, 2015.
  1. Jan 28, 2015 at 12:18 PM
    tacoturd913
    tacoturd913 [OP] Member
    KY
    09 TRD Off Road Prerunner SR5
    Hey all,
    Newbie here and recent owner of a new beautiful '09 Prerunner TRD Off Road SR5 Taco (love her). I've seen several posts on here concerning vibrations on the front end but none that fit all of the criteria that I'm currently experiencing.
    I bought this thing used aware of some needed brake pad and rotor replacement for the front end. I managed to talk the dealership into providing replacements which I installed but I am still experiencing heavy vibration while stopping at highway speeds and small fine vibrations when coming to a complete stop within 4 feet of actually stopping.
    All of the vibration is felt in the steering column with a tad felt in the pedal. Done what research I can and this may point to bearing issues but haven't heard the telltale grinding noise.
    Anybody know of a thread already handling or can you provide some feedback?
  2. Jan 28, 2015 at 1:56 PM
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    Subd...
    I'm experiencing the same issue. Steering wheel vibrates side to side during braking only. I got a new set of rotors and pads that i will install this weekend.
  3. Jan 28, 2015 at 1:59 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Are the tires and alignment good?
  4. Jan 28, 2015 at 2:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I dunno, installed a pair of Bamatoys wheel bearings and the truck is quiet as a mouse. It's almost eerie. Give Bamatoy a ding.
  5. Jan 28, 2015 at 2:03 PM
    tacoturd913
    KY
    Tires are good. Though I've never had the alignment tested, it doesn't drift at all or pull while breaking. I've ruled these out because it rides perfect unless I'm braking. Am I mistaken?
  6. Jan 28, 2015 at 2:04 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    When both of you installed rotors have you check backlash ?
    Are all bolts torqued to spec?
    Are your wheel bearings in good shape ?
  7. Jan 28, 2015 at 2:12 PM
    BlueT
    NorthEast
    Bad wheel bearing could do something like that, Its unlikely but worth checking.
    Also sometimes when people put new rotors they dont go exactly as they should (rust, stuck on something) that would make continues vibe.
    Lastly msot common mistake wheel nuts are not tighten correctly
    Grab torque wrench and check you wheel nuts if they wrong you will warp new rotors in no time.
  8. Jan 28, 2015 at 2:14 PM
    tacoturd913
    KY
    All of the above are being tested Friday. This was a home job and I'm limited on tools. Hypothetically speaking, if lugs are good and cleared on backlash test, what might I be looking at?
  9. Jan 28, 2015 at 2:53 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    If wheels balance and torqued to spec, it's hub bearings. With front end off the ground, grab tire at 9 and 3 o clock, if it has play, you need new bearings. Bama units look real good for price.
  10. Jan 28, 2015 at 3:00 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    whats the lbs they should be tightened to?
  11. Jan 28, 2015 at 3:04 PM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    85 ft-lbs
  12. Jan 28, 2015 at 3:22 PM
    tacoturd913
    KY
    Link for a vendor on bama parts?
  13. Jan 28, 2015 at 3:41 PM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
  14. Jan 28, 2015 at 3:42 PM
    Pavlovsdog
    Pavlovsdog Active Member
    Tampa, FL
    07 PreRunner 2WD
  15. Jan 28, 2015 at 4:57 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Check for uneven tire wear, bubbles on the sidewall, and just the overall condition of the tires. My brother had a similar issue on his 2013 Tacoma. New pads and rotors didn't solve anything, but after he added a new set of tires the vibrations went away.
  16. May 18, 2015 at 12:31 PM
    IslandBoy71
    Reggie
    Lakewood, CA
    New pads and rotors installed and.......problem solved!!
