Front End Vibration/Humming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by birry, Jul 15, 2013.
  1. Aug 5, 2013 at 3:14 PM
    birry
    birry [OP] Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I'm having some trouble getting the axle nut off. I don't own an impact wrench. Is it possible to do it with a simple breaker bar? Also, I assume I'll need to torque that back down to a specific torque when I put it back on, is that correct? Or do you just tighten "really tight"?
    Thanks for the help!
  2. Aug 10, 2013 at 4:27 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    In case anyone is following this thread - I replaced the wheel bearing and that was it.
    Boom. Problem solved! It sounds smooth and perfect.
    Now I gotta attack that dash rattle and the cabin air filter....
  3. Aug 11, 2013 at 7:22 AM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Right on! Was on Vacation and didn't log in for a bit. Glad you got it solved. I just took about 1000mile trip with mine and it is great having the smoother ride back!
  4. Aug 12, 2013 at 5:14 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Nice. It was really nice to get the smoothness back, and the job really wasn't that hard (once I got the proper tools). I wound up buying a breaker bar, a 17mm wrench, and 35mm axle nut socket and just got the torque wrench from Autozone (on loan).
    I accidentally forgot to put the brake shroud back on the first time, so I took the bearing assembly out and put the brake shroud on. Then I realized the brake shroud was on backwards, so I had to take the whole thing out again and put it back in.
    In all honesty, the hardest part was getting that little safety pin put back in after the axle nut was torqued down. That thing was a beotch. Most everything else was relatively simple.
