Front end vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by YoaterBoater, Nov 16, 2011.
  1. Nov 16, 2011 at 9:00 PM
    YoaterBoater
    YoaterBoater [OP] Well-Known Member
    Mississippi
    2002 PreRunner DblCab
    Running tubes, Toolbox
    I took my truck down some trails this past weekend but it was nothing serious. Just dirt trails going down a gas line and ever since then ive noticed a little bit of vibration around 50mph. Ive been hearing a rattling noise when I hit a bump but I didnt think much about it, because a while back, that bracket that is on the caliper came loose. I guess the pin worked its way out and cause it to tick a little bit. I popped the wheel off and fixed it, no rattling. So I dont think that noise has anything to do with it just thought I would throw that in there. Anyways, I was wondering if it could just be my alignment or maybe a weight balance issue on the rim. Seems like this would be a common problem for those that do some trailing. Is this an easy fix for someone that is decent with tools or should I take it somewhere?
    Thanks in advance
  2. Nov 16, 2011 at 9:04 PM
    tacomacntry
    tacomacntry Joe's Auto Detail
    North East Florida
    Blacked out SR5 4x4
    K&N Cold air Cat back custom dual exhaust
    could have knocked a weight off...im sure you may have checked that...and a little mud on the inside of the wheel will def throw your balance of to a noticeable vibration!! keep em clean and make sure nothing came loose! could be ball joints!
  3. Nov 16, 2011 at 9:05 PM
    YoaterBoater
    Mississippi
    Im gonna take a close look at them tomorrow. I really hope it isnt ball joints. Ive heard they are a pain to replace.
  4. Nov 17, 2011 at 5:40 PM
    YoaterBoater
    Mississippi
    I took my tire off just a few minutes ago and found that the bushing on my lower control arm is gone. Can anyone give me an idea on what its gonna take to fix it? Or should I just take it to a shop? If so, about how much would the repair be?
  5. Nov 17, 2011 at 10:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Which bushing? The LCA has 2 bushings on the frame side and a balljoint on the tire side.
    Can you take a pic of the bushing in question?
