Front end vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota Man, Aug 5, 2014.
  1. Aug 5, 2014 at 7:56 PM
    Yota Man
    Yota Man [OP] Taco enthusiast
    Cole
    Red Deer, Alberta
    '14 TRD Sport Storm Trooper
    3" Revtech leveling kit, 17x9 XD Revolvers on 275/70/R17 BFG K02s, smoked mirror signals, Spyder tail lights with aftermarket tint, Bulletproof Fabricating grill, debadged everything, trifecta tonneau cover, Flowmaster 40 series cat back exhaust with 4'' MBRP exhaust tip, Black headlight mod and tint, L.E.D. reverse, license, and all interior lights, AJT shifter, more to come.
    2014 double cab sport 4x4. Leveling kit 3" front 1" in the rear, and differential drop. 265/65/17 wheels. Only 13,000km. At 8,500 km on the truck I was cruising through the city when I noticed a very faint vibration in my pedels. Only between 60-70 km/h. As I was on my way to the dealership for its first servicing anyway I figured I'd get them to check it out. They told me I needed my tires balanced. Which I thought was odd seeing as I only had about 500 km on my new skins, but I went back to the tire shop and they balanced all tires again. Vibration didn't go away. But got worse, now I can feel it and hear it if I really listen. I take it back in to the shop two weeks later. Im told they rotated the tires front to back and the noise was completely gone. I pick up the truck and notice right away the noise is still there bit I leave for work for two weeks and was hoping maybe it was just a slight vibration from after the rotation and wanted to see if itsy go away. Well almost a month since then it has gotten to the point where I can feel it in my steering wheel and hear it constantly. The noise is not a constant tone, but a violent hum every second or so. I have checked my cv joints, ball joints, brakes, wheel bearings, and the dealership said they can't find anything. Nothing in the differential oil as for shavings or signs of wear. Im running out of ideas, any information or thoughts is appreciated. Thanks guys.
  2. Aug 5, 2014 at 8:14 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    I remember reading somewhere on here that Tacomas need to have their tires balanced by a special type of balancer. I kno that guys have suggested going to Firestone and having them do the roadforce balacing. But idk if you have Firestones in Canada so your other option would be having the dealer balance your tires and see if that helps
  3. Aug 5, 2014 at 8:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    10 bucks says front diff passenger side CV output needle bearing slop. I bet if your crusing at the 60-70km/h and pop it into 4x4 hi (on a straight stretch of road) the noise and vibrations will go away if so...
    60 bucks for the ECGS bushing and problem solved.... also remove that diff drop when you do the bushing.
  4. Aug 5, 2014 at 8:30 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  5. Aug 6, 2014 at 4:58 AM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    All your problems are very common OP, do some research on here you will find your answers.
  6. Aug 6, 2014 at 5:09 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    x2 on the diff bushing and ditch that diff drop. Also if your wheels are not hub centric make sure that are properly centered
  7. Aug 11, 2014 at 2:22 PM
    Yota Man
    Cole
    Red Deer, Alberta
    Ended up just needing to get the dealership to balance it with their balancer. All is peachy again! Thanks
  8. Aug 20, 2014 at 11:42 PM
    Yota Man
    Cole
    Red Deer, Alberta
    Okay sooooooo, turns out the vibration came back. I thought my Toyota dealer had a road force tire balancer which is why i thought it worked this time. Well apparently the woman working the desk that day didn't know what she was talking about because they in fact don't have that balancer. Finally found a local tire shop which does and although it cost me 40$ bucks per tire... I got it fixed. Turns out one of my XD wheels is a fraction smaller than the rest. Literally just enough to cause an annoying vibration even after being balanced. Well the road force worked and i guess I'll have to use that from now on. Just glad I finally got rid of the vibration.
