Front end wobble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tear, Dec 31, 2020.
  1. Dec 31, 2020 at 9:18 AM
    tear
    tear [OP] Member
    terry kryst
    2019 tacoma sr5 doublecablongbed 4x4
    arb front and rear bumpers
    Has anyone had front end wobble like the front end is out of alignment or wheels need to be balanced. I just replaced my stock 245/16 with a 17 inch trd 265/70 bfgoodrich ko2 tire. I will bring it back in to see if brand new wheels need to be balanced. Thanks
    CrufflerJJ likes this.
  2. Dec 31, 2020 at 11:34 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Double check your lugs
  3. Dec 31, 2020 at 11:41 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    its the tires
    vanrynd likes this.
  4. Dec 31, 2020 at 12:04 PM
    tear
    tear [OP] Member
    terry kryst
    A local shop installed the wheels, lugs are tight. I have 15 inch k0s on my 92 toy smooth as silk.
    Anoyying vibration is it possible they didnt balance wheels correctly .I have bilsteen 5100 with old man springs in front with a
    block in rear. The truck looks awesome with wheels,but with the shimmy in front is not cool.
  5. Dec 31, 2020 at 12:20 PM
    philth
    philth .
    Improperly balanced rubber, bad rubber, bad rim.
    First priority would be taking it back to the shop and having them recheck their work. Ask if they had any issues mounting the rubber to the rim.
    Where did you get the rims? are they aftermarkets? are they used/new?
    Not sure why the strike through appeared, but ok.
  6. Dec 31, 2020 at 12:20 PM
    SpeySquatch
    2016 TRD OR DCSB
    i run the 17" TRD PRO 4Runner (SEMA) wheels and they have been cherry at all speeds. Could be the tires, could be that you need a few extra weights on the wheel to balance with your tires...not all tires are shaped perfectly
  7. Dec 31, 2020 at 12:35 PM
    VLTHNTR77
    VLTHNTR77 Well-Known Member
    Andrew
    Everett, WA.
    2016 Inferno TRD off-road
    RCI skid and sliders, GoodYear Ultraterrains, HID's, SCS SR8s, lots of ME-SO goodies, Diamondback HD.
    Ko2's seem to be nearly impossible to balance.
    I had mine re balanced at least six times without much difference.
    I dealt with it for 4 years and then changed them out for Goodyear Wrangler Ultraterrains.
    Way happier with the Wranglers.
  8. Dec 31, 2020 at 1:05 PM
    tear
    tear [OP] Member
    terry kryst
    Thanks .On my 92 toy truck been running those tires for years nice and smooth.
    Brand new trd 17x7 wheels from toyota.Does front end need to be aligned from going from 245/16 to a 17 265/70?
  9. Dec 31, 2020 at 4:11 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is it a genuine wobble or more of squirmy vagueness?
  10. Dec 31, 2020 at 6:17 PM
    tear
    tear [OP] Member
    terry kryst
    Old man emu springs and 5100 shocks installed earlier in year with no problems, until I had the larger tires and wheels installed.
    Thanks
  11. Dec 31, 2020 at 6:30 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    K02s are like many products, inconsistent. You are entering the lottery when you buy a set. A decent amount are impossible to perfectly balance. I went through two sets personally. First set was terrible and out of spec which BFG was willing to replace. Second set is in spec but still not perfect.
  12. Dec 31, 2020 at 8:28 PM
    tear
    tear [OP] Member
    terry kryst
    Thanks sir,that was the most reasonable theory, The truck looks like it should stout. Before with those puny 245/75 16" tires they would screatch around small corners. I was going to use the same wheels but found out the 17" tires were 50 dollars less, and the 17" wheels looked better.
  13. Jan 1, 2021 at 11:15 AM
    tear
    tear [OP] Member
    terry kryst
    Do you think when they were balancing , they knew that it wasnt balanced right. And its not the 4 runner 17 " trd wheel?
  14. Jan 4, 2021 at 6:45 PM
    tear
    tear [OP] Member
    terry kryst
    Did they replace all four?
  15. Jan 4, 2021 at 6:52 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Did they balance with cones in the center bore? Have them do a Lug Centric balance. Balance with a device that mounts the wheel to the balancer via the stud holes. Then let us know.
  16. Jan 4, 2021 at 7:18 PM
    splitbolt
    NW Arkansas
    I'm a little confused...may be the way it's worded.
    Is it or is it not a genuine TRD wheel?
  17. Jan 5, 2021 at 4:43 PM
    tear
    tear [OP] Member
    terry kryst
    Trd wheel from toyota yes. 17x7 wheel I believe it was for the 4runner.
    when I drove out from tire shop it was obvious something was shimmering or wobbling, called the shop and said the tire is going to ride differently from stock tires. I have had multiple ko2 tires on my 92 toy with nothing close to this problem
  18. Jan 5, 2021 at 4:53 PM
    tear
    tear [OP] Member
    terry kryst
    They wanted to know if went up a size ,told them I went from a 16"245/70 to a !7" trd wheel. 265/17
    Of coarse they said because I went up a size that is probably the problem. They only do road centric balancing. Thanks
  19. Jan 5, 2021 at 5:48 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I'm in, what are we talking about?
  20. Jan 5, 2021 at 5:57 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Where do you live?
