Front Higher than Rear
Discussion in 'Suspension' started by JGJ, Jan 20, 2011.
  1. Jan 20, 2011 at 8:46 AM
    JGJ
    JGJ [OP] Well-Known Member
    I got the full 3" OME lift with 886 coils (heavy) and Toytec AALs on the rear.
    My front sits a tad higher than my rear.
    I'm afraid to put any weight (trailer, bed cap, etc) for fear it will raelly look saggy.
    I want to lift my rear suspension another 1" at most to level it out.
    What are my best options?
    You can see my truck on my profile pics
    Thanks
  2. Jan 20, 2011 at 8:49 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    probably a new leaf pack. You might be able to put another aal in but I bet it will ride like shit.
  3. Jan 20, 2011 at 8:50 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I think the bro-lean matches the rockstars perfectly.
    But seriously now....did you get the 2" or 1.5" toytec AAL? If you are already at the 2", your options are a 1" block, or you could go with a new 3" leaf pack. I'm not sure anyone makes a 3" AAL.
    How long has the front had to settle? Mine took a day or two to sag back down to where it currently sits.
  4. Jan 20, 2011 at 8:50 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  5. Jan 20, 2011 at 10:11 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    How long have you had the lift installed? You may need to run an 885 coil set up front.
  6. Jan 20, 2011 at 10:16 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Well since he's a 4x4 DC LB the 886's are probably his best choice cause of the extra weight. But yeah, what size AAL are you running in the back? If you got a full 3"s up front, you will need at least a 2" AAL to level you out. A 1.5" will give you that rear sag for sure. And like the others said, how long have you had that lift setup for? Mine took at least a few weeks to finally settle in, maybe even longer then that.
  7. Jan 20, 2011 at 10:22 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    probably needs to settle a bit too
  8. Jan 20, 2011 at 12:28 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you can add a shackle in the rear but then maybe your tires will start to look small. It never ends.
  9. Jan 20, 2011 at 1:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 886's are only to be used on a truck running a heavy bumber/winch
    Sounds likr you got the wrong springs
  10. Jan 20, 2011 at 6:23 PM
    JGJ
    Hey guys, I've had the lift on for at a few months now. So it has had time to settle.
    I'm not exactly sure if my aal is 2" or 1.5". Its the standard one that comes with the OME lift from Toytec. Checking their website I can't make out which one it is for certain.
    I was told by Toytec today that the 886 coils will produce a highr than 3" lift without a aftermarket heavy bumber (as a couple of you have already mentioned).
    I like the height of the front - and I'm definately not taking that thing apart again (coil compression, etc). So I think the 1" block is gonna be my best bet at this point.
    Thanks for the help guys,
