Front Hitch Motorcycle Carrier?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ravenous, Apr 22, 2017.
  1. Oct 14, 2023 at 9:55 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I’ll respond too…I alternate using mine for a front receiver tray winch, transporting my heavy eBike, pushing my RV trailer into tight traces with not easy access, and occasionally my Honda Trail 90 when we’re pulling the trailer. No probs with weight although I’m lifted about 1.5” up front with 5100’s.
  2. Nov 17, 2024 at 10:49 PM
    atoratog
    atoratog Member
    2020 OR
    I see someone on Amazon used the Curt front hitch to carry a full-size dirt bike.
    I just ordered and will test it out.
  3. Nov 24, 2024 at 10:50 PM
    atoratog
    atoratog Member
    2020 OR
    it works well. it significantly reduces approach angle but should be good for light off roading to camp.
    I'm using a curt front hitch with a rack n roll carrier.
    the stabilizer anti-sway setup doesnt quite fit so I'll have to rig something up.
    it is ok to drive but will probably block my lights for nighttime driving.
  4. Nov 24, 2024 at 10:50 PM
    atoratog
    atoratog Member
    2020 OR
  5. Nov 24, 2024 at 11:06 PM
    OnHartung'sRoad
    …putting the ebikes up front keeps them from getting gunked up from off-road dust also.
  6. Nov 25, 2024 at 7:53 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    You have the bike a full 12" from the front of the Taco. That long arm works like a fulcrum creating a lever of mechanical advantage (or in this case disadvantage) adding substantial weight to the front hitch. Also that 2' joist could act like a pole vault.
