Front hood making annoying vibrating noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03tacocruiser, Oct 26, 2023.
  1. Oct 26, 2023 at 11:35 AM
    03tacocruiser
    03tacocruiser [OP] New Member
    Brycen
    2003 Toyota Tacoma ext cab tan 2wd
    New door handles
    At warm up engine rpm’s, those rpms cause the area up front to vibrate making a really annoying vibrating noise. The noise settles down after the engines rpm’s get to a certain point. If I pull the hood latch or press down on the front of the hood, the noise goes away. The vibrating noise is right up front under the hood. I’ve checked around that area and can’t see any obvious source of the noise. Any ideas where I should check?
  2. Oct 26, 2023 at 11:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    treyus30 likes this.
  3. Oct 26, 2023 at 1:00 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Try putting, squirting some white lithium on the hood latch hook and pivot point. I had a squeak driving me crazy a while back and that flat stopped it. I also shot some into the hinges too. It fairly certain it was the latch, probably the hook on the loop portion. Good stops were fine also.
  4. Oct 26, 2023 at 1:50 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Look for these. They keep the hood tensioned so it doesn't rattle around on the latch. Your latch could also be worn out.
