Front Hub and Bearing ?s
Discussion in '1st Gen. Tacomas (1995-2004)' started by motoedde, Mar 5, 2012.
  1. Mar 5, 2012 at 8:32 AM
    motoedde
    motoedde [OP] Member
    Edde
    Philly, PA
    '96 Tacoma 4x4 2.7L shortie
    A couple weeks back, I replaced the front rotors and pads on my 96 Tacoma. I had the dealer do it as well as bleed the entire system, as I didn't have time.
    Before I replaced the pads I heard a loud scratching sound that came from the passenger side front wheel. Once the pads and rotors were replaced, the sound went away and for over a month I've been driving without the noise.
    Last night, the same scratching noise appeared again so I took it back to the dealership. They claim the passenger side front hub needs to be relubed and the bearings need to be repacked with grease as they're dry. The front hub has to be manually locked, and is noticeably easier to turn than the driver's side. Last year due to an accident, my front hub assembly on the driver's side was replaced by another dealer.
    I didn't think you could repack these bearings as they are a sealed unit. Any thoughts?
    Also, when a new hub is installed, should it be difficult to turn and lock the hub as is the case on the drivers side?
  2. Mar 5, 2012 at 8:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    The bearings are not a sealed unit. And all of my locking hubs vehicles were a little difficult to turn sometimes.
  3. Mar 5, 2012 at 8:45 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    x2^ Also, I just rebuilt my manual hubs and they're still a bit difficult to turn... It's just the way they are I think.
