Front hub bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skeeter18, Apr 30, 2012.
  1. Apr 30, 2012 at 1:19 PM
    Skeeter18
    Skeeter18 [OP] Member
    Richard
    Pa
    Tocoma
    Do i need to pull the axle to replace the front wheel bearing 2005 tacoma and what size is the nut on the hub
  2. Apr 30, 2012 at 1:20 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Yes, and 35mm. You also need a shop press.
  3. Apr 30, 2012 at 1:56 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    Is the bearing in the hub assembly or on the axle or are there 2 bearings
  4. Apr 30, 2012 at 2:06 PM
    mjp2
    NJ
    The bearing comes as a unit that gets pressed together with the hub and bolted to the spindle. The axle together with the axle nut holds the whole assembly together.
  5. Apr 30, 2012 at 2:07 PM
    mjp2
    NJ
