Front hub dust cap on aftermarket hub, won’t fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrlowscot, Aug 26, 2022.
  1. Aug 26, 2022 at 5:40 AM
    Jrlowscot
    Jrlowscot [OP] Well-Known Member
    Iron Station, NC
    09 DC Off Road
    Did my drivers wheel bearing and axle needle bearing/ bushing swap. I bought a hub /bearing assemble that uses an aftermarket “asian” hub. Quality was good, my issue is I can’t get the dust cap on the new hub. It must be a smaller diameter. It was super tight on the original, but I can get it started on the original but not close on the new hub.
    Any suggestions on solving this? I tried crimping the edges around but didn’t help. I don’t have a precise way to measure. Next step may be to cut 2-4 slots to allow it to compress more, but worried about getting water in it.
  2. Aug 26, 2022 at 7:00 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You might have to buy the dust cap from the same manufacturer. I don't think I'd trust a cut and crimped cap. The joys of aftermarket parts.
    Jimmyh likes this.
  3. Aug 26, 2022 at 10:10 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I popped mine in with a rubber mallet. It was a tight fit but aligning it properly and smacking it from multiple sides eventually got it in.
    There should be a stamp on the hub from the manufacturer - you could always just go buy a cap from them to see if the cap has compatible tolerance with the tub
  4. Aug 26, 2022 at 10:36 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    No way to file down the cap with a grinder or file? And also a little on the hub? Throw on a little grease and whack with a rubber mallet. I think I remember getting it started by gently tapping the edge of the cap with a screwdriver. I bought one as a backup in case I broke one but never did and still have that cap. Think it was twelve bucks, about ten years ago. I see the prices haven't gone down.
    tacoman45 likes this.
  5. Aug 26, 2022 at 4:41 PM
    Jrlowscot
    Iron Station, NC
    09 DC Off Road
    I ended up cutting 4 slots with a dremel and pounding on with a rubber mallet. Should have RTV’d but I won’t go in any water.
  6. Aug 26, 2022 at 6:47 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    For future reference, I had the same problem last week. Just use a pair of pliers or Channel Locks, carefully bend the leading edge in, just a little at a time and keep working your way around it. I had to do it five or six times, all the way around before it was tapered in enough to get it started. They, rubber mallet and whack the crap out of it.
    Jrlowscot[OP] likes this.
