Front IFS Diff Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Nov 11, 2012.
  1. Nov 13, 2012 at 7:52 AM
    #41
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Putting a front locker is on my future wish list, if I can get a unit that just drops in my housing with almost factory resemblance I'm in. Not sure why everyone is so caught up on the whole not having support thing, your basically putting in a Toyota Tacoma E-locker diff in the front vs the rear of the car. To me it's no different than guys wiring up their rear E-lockers to activate any time they want it
  2. Nov 13, 2012 at 8:39 AM
    #42
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I don't think you understand differentials and lockers, but that's okay.
  3. Nov 13, 2012 at 8:48 AM
    #43
    cjimenRR
    North Hollywood, Ca
    If you're referring to me I know a little bit more about cars than the average joe. I think we're all missing the point of the OP idea behind all this. He's obviously willing to shell out the money to see if this will work but is asking us for some help on data to prove him otherwise. Good luck OP and and keep us updated. Also sub'd the thread :)
  4. Nov 13, 2012 at 8:55 AM
    #44
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    What e locker is there for the front of an 05+ tacoma?
    I only know of ARB air actuated lockers for the front.
  5. Nov 13, 2012 at 9:22 AM
    #45
    cjimenRR
    North Hollywood, Ca
    There isn't, I was referring to the one OP found for Toyota Hilux on the other side of the world.
  6. Nov 13, 2012 at 9:36 AM
    #46
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Did you even read this thread?
  7. Nov 13, 2012 at 9:39 AM
    #47
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The real question is which would be cheaper in the long run? ARB in the front with the price of the air system or this e-locker. If the ARB is cheaper there's no reason to get the e-locker in my opinion since you'd also get the benefits of having an onboard air system too.
  8. Nov 13, 2012 at 9:54 AM
    #48
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    on top of this, no ones even thrown out what axles you'll need, how its going to bolt up, and how to actuate it.
    Someones got some good pipe dreams here, but unless its plug and play, which it wont be, no one will buy it.
    Nonetheless....
  9. Nov 13, 2012 at 9:58 AM
    #49
    Spoonman
    Jamie
    Alberta
    I thought we were talking about front lockers for 2005+ tacomas :confused:
  10. Nov 13, 2012 at 10:01 AM
    #50
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    What about a front locker out of an FJ Cruiser?
  11. Nov 13, 2012 at 10:04 AM
    #51
    Spoonman
    Jamie
    Alberta
    Same differential. FJs aren't locked in the front
  12. Nov 13, 2012 at 10:06 AM
    #52
    nat
    2007 DC SB Tacoma
    I thought some FJC's were available with a front locker. Maybe not.
  13. Nov 13, 2012 at 10:09 AM
    #53
    Spoonman
    Jamie
    Alberta
    Just the rear like TRD offroad tacos
  14. Nov 13, 2012 at 11:49 AM
    #54
    cjimenRR
    North Hollywood, Ca
    ^------- this is the bottom line for all interested
  15. Nov 13, 2012 at 12:10 PM
    #55
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Just get an ARB and call it a day. I have had mine for quite a while now. Never had ANY issues. The front (non-modified) CVs on the second Gen Taco are very strong. I have had it locked with the wheels cranked all the way over, in Aftershock (Part of the hammers Trails). Never had an issue.
  16. Nov 13, 2012 at 12:29 PM
    #56
    Spoonman
    Jamie
    Alberta
    So awesome.
  17. Nov 13, 2012 at 12:32 PM
    #57
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Good to hear I just had an ARB installed up front cant wait to put it through its paces. Brandon are you running stock gears ( 3.73:1)?
  18. Nov 13, 2012 at 3:34 PM
    #58
    BradyT88
    BradyT88 Well-Known Member
    I doubt it would be any harder to wire up than a compressor. You just add a switch and probably some relays to activate it. Sure it isn't going to wire in like the rear e-locker, but it should still be pretty easy after some research on what the locker needs from the ecu, etc before it will lock (if it even needs any of that).
  19. Nov 13, 2012 at 5:04 PM
    #59
    badger
    badger Well-Known Member
    07 SR5
    Well,
    I have two questions that the OP should try to answer before shelling out the money for a trial.
    #1, The Elocker rear is well known to be weaker than the "8.4" version with an ARB insert for the rear. Would the same be true of the front? If so = no go.
    #2, The front diff on the Tacoma lacks proper bearing support of the axle, which can cause vibrations on lifted trucks. The addition of an ARB provides all the supported needed. Would the Elocker version still have the bearing problem, or has that been fixed in the Hilux axle? If it does have the problem will the ECGS bushing fit?
    In my mind, if either of these things has a negative answer the project is still born :(
  20. Nov 13, 2012 at 5:38 PM
    #60
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    http://www.arb.com.au/media/products/air-lockers/application_chart.pdf
    The part numbers for the 05+ HiLux and 05+ Tacomas are the same here.. So I would assume they would work..
    Air systems suck up here in the cold winters.. I am a H.E.T. in a mine and I spend my winters thawing out air systems..
    I am with Ghost on this. An E-Locker would be my preference as well..
    Now is there one that will fit the rear of an TRD Sport DCLB??
