Front IFS Diff Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Nov 11, 2012.
  1. Nov 21, 2012 at 11:00 PM
    #161
    Ghost848
    Ghost848 [OP] Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    See not just me!
  2. Nov 21, 2012 at 11:09 PM
    #162
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Ok. You want the A11110 if you are going to regear to 4.56.
  3. Nov 22, 2012 at 8:41 AM
    #163
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looks like the email to ZUK specified what you need. Read that again.
  4. Nov 22, 2012 at 9:18 AM
    #164
    Ghost848
    Tony
    Alberta,Canada
    It did but it still doesnt make sence ... Maybe im retarded?lol... He says 3.73, but im being told by others 3.91
  5. Nov 22, 2012 at 9:50 AM
    #165
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    AFAIK the ARB air locker is engaged "blind". With the rear e-locker, there's a warning light that will flash until the locker is fully engaged, then illuminate solid. AFAIK this is not a consistent process and you have to drive a little bit, turn the steering wheel, etc. for the locker to engage. Do you plan to have a similar indicator lamp wired into the cockpit for the front locker?
  6. Nov 22, 2012 at 9:57 AM
    #166
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    looking at it Ghost
    did you tell him you were going with xtra thick cut gears??? if so than yes you need th 3.73 and lower carrier,
  7. Nov 22, 2012 at 10:09 AM
    #167
    Ghost848
    Tony
    Alberta,Canada
    Yes zuk id the extra thick gear so he suggested 373... As for the indacator i imagin having an illuminated switch like the arb is possible, but im planning on making it look stock so im thinking a red led or something
  8. Nov 22, 2012 at 11:56 AM
    #168
    BradyT88
    BradyT88 Well-Known Member
    I think this would be really hard to do unless the locker is designed for it like the rear e locker and the front ADD. They have limit switches that are triggered when the locker/ADD slide into place that tell the ECU they are engaged. The front ARB for our diffs only has an airline coming from it. Nothing electical, so there is no indicator for whether it is locked in or not. Just the light for when the switch is on or off.
    So if the after market lockers dont have limit switches, adding them could be tricky if even possible.
  9. Nov 22, 2012 at 12:40 PM
    #169
    Spoonman
    Jamie
    Alberta
    Why would you want a limit switch? Safe guard against accidental engagement?
    Take the power for your front locker from the power wire for the rear locker. If you can't lock the rear, you can't lock the front. No power. Just an idea, not sure on the wiring of the front e locker.
  10. Nov 22, 2012 at 4:23 PM
    #170
    Ghost848
    Tony
    Alberta,Canada
    is thereanyone intrested in a group buy.... pm me if intrested and ill make a list im thinking need at least 5 to make it worth while. im shooting it out there. in the mean time ill keep on trucking...so its looking like 373 model is the one to be getting for the 456 thick gears...
  11. Nov 22, 2012 at 4:53 PM
    #171
    KenLyns
    Belly of the Beast
    Does your ARB front locker engage easily when you hit the switch (no need to drive forward, turn the steering wheel, etc.)?
  12. Nov 22, 2012 at 5:11 PM
    #172
    KenLyns
    Belly of the Beast
    Ah, that's the difference. I think an e-locker, if it works the same way as Toyota's, will require an indicator light. If you apply full throttle before the locker fully engages, you can potentially damage the locker.
  13. Nov 22, 2012 at 5:11 PM
    #173
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    How much is it?
  14. Nov 22, 2012 at 7:10 PM
    #174
    BradyT88
    Yeah, limit switch might not have been the right wording, sensor maybe (I just assumed it was like a push button switch). haha. I don't know what the setup looks like physically in the A.D.D. but there are 2 limit switches and a "sensor". The sensor is what tells the ECU that the ADD is engaged. So when I did my 2Lo mod, I had to ground that sensor so the ECU thinks the ADD is engaged when it isn't.
    I would assume the locker would need to have a similar sensor to tell your light that it is locked in. The front ARB has no such sensor so you would have to add one somehow yourself if you wanted one.
    My front ARB engages damn near instantaneously most of the time, but the front tires, when turning, can line up the locker much faster than the rear can due to more varying wheel speeds. Disengaging can be a lot slower sometimes though, but with the front locker it is really easy to tell whether it is engaged or not because the steering is really stiff when it is engaged.
  15. Nov 22, 2012 at 10:39 PM
    #175
    Ghost848
    Tony
    Alberta,Canada
    The elocker is not like toyotas! The electro magnetic is instant locker were it slides the locking pind on bearing sytem that locks the diff. No turning no driving forwared, instant.
    I got it priced to from aus to my door here in canada 1684.00 shipped
  16. Nov 23, 2012 at 8:29 AM
    #176
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Add customs of a minimum 5% of they ups add 200ish if they use aus post add another 100ish
  17. Nov 23, 2012 at 8:48 AM
    #177
    BradyT88
    I see. Why didn't Toyota just use a locker like that in the first place?:p
  18. Nov 23, 2012 at 9:58 AM
    #178
    Spoonman
    Jamie
    Alberta
    Even with eaton style lockers you have to drive forward and backward to engage it. Unless its perfectly lined up when you press the button. I have experience with them. They're a pain in the ass to engage. This was on the rear of a vehicle.
  19. Nov 23, 2012 at 10:17 AM
    #179
    BradyT88
    Any links for good info on how the various lockers engage internally?
  20. Nov 23, 2012 at 5:48 PM
    #180
    KenLyns
    Belly of the Beast
    5% GST + $60 UPS handling fee. If part is subject to duty (not made in a NAFTA country), add another 10% or so. That's Kanada for you.
