Front leaf bolt size?
Discussion in 'Suspension' started by cmf21, Jun 17, 2011.
  1. Jun 17, 2011 at 9:06 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    In case I need to get new hanger pin bolts for my new rear leafs, what size of bolt do I need. I don't want to have to order any if I can just pick them up from Home Depot or somewhere.
  2. Jun 17, 2011 at 9:18 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    front leaf :confused:
  3. Jun 18, 2011 at 7:39 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Anyone?
  4. Feb 24, 2012 at 3:11 PM
    GVY
    GVY All those moments will be lost in time
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Bushwacker Cut-Out Fender Flares, ARB Winch Bull Bar, 3" All Pro Bilstein Coilovers, All Pro UCAs, Wheeler Off Road Custom Rear Bumper, All Pro Standard Leaf Pack, Bilstein 5125 rear shocks, All Pro steel-braided brake lines, U-Bolt flip kit, JBA cat-back exhaust, KC 6" Daylighters & 2x6" driving lights, AFE Pro Dry Air Filter, Deck plate mod, Toytec 1" shackles, Rhinolined bed, Tiregate Prerunner, Procomp 85 gloss black steel wheels, 285/75/16 Toyo Open Country M/Ts
    I'm bumping this because I'm looking for the same info. What I think the OP means, and what I mean, is the size of the bolt on the front hanger pin for the leaf springs. Mine are stuck like chuck and I'm going to have to replace them just by getting em out. This will keep me from having to drive out with the old bolt and matching it up.
  5. Feb 24, 2012 at 3:28 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Instagram- venturajuan23
    Check your local auto parts store they can search for you and possibly have one in stock
  6. Feb 24, 2012 at 8:16 PM
    GVY
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Yeah, true. I was looking for the size online but there's really nothing stating an exact size. Guess that's the best bet at this point.
  7. Apr 4, 2012 at 7:51 PM
    gkozun
    gkozun Member
    Ontario, Canada
    Anyone figure out the size of these bolts yet? I would like to get some standard Gr. 8 bolts & drill them out in my lathe & make them greasable. I need the size of both the front hanger pin & rear shackle bolts. About to do some rear suspension work and have a feeling I will be cutting the old ones out. Just want to have the new bolts beforehand so I am not stranded without wheels after pulling the old bolts out to measure them.
  8. Jun 11, 2012 at 8:20 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    Bump.
    I'm running into the same problem
  9. Jun 11, 2012 at 8:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well the hanger bolt head is 19mm & I'm going to take a stab here & say the diameter of the threaded stem is 14mm
  10. Jun 11, 2012 at 9:35 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    You mean the shank/shoulder is 19mm? Do you know the length of the shank?
    I called a couple dealers and they had no clue.
    Anyone know anything about the bolts for the rear shock? I know they are 12x1.25 but cant find anything local.
    Thanks
  11. Jun 11, 2012 at 11:16 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not the shank, the head of bolt is 19mm (19mm socket to remove)
    & I'm just guessing at the 14mm shank size , but I bet I'm close..
  12. Jun 11, 2012 at 11:17 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The shock bolts are 17mm to remove, not sure on shank size
  13. Jun 11, 2012 at 11:30 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    Lol your right I wasn't even thinking been searching all over for one.
  14. Jun 13, 2012 at 3:36 PM
    gkozun
    gkozun Member
    Ontario, Canada
    Bolt size is M14 x 1.5 x 100mm long. Grade 8. I had to pay $17/each for them @ the dealership up here in Canada. Found out the size after I bought the new ones. You should be able to get them from a local auto parts store or nut & bolt supply for much cheaper.
    Do yourself a favour & buy new front bushings as well. No amount of pounding was able to get the cut bolts out of them. I then tried drilling them out unsuccessfully. It got so hot the rubber was destroyed. Was able to get them through UAP NAPA.
  15. Jun 13, 2012 at 3:40 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
  16. Jun 15, 2012 at 10:16 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    A 9/16 works. I had to get it at fastenal as nowhere else had one with a long enough shoulder. I ordered two at the dealer for next time.
    I'm really surprised I haven't seen this in any how to on changing leafs, I would definitely suggest just getting some before starting, it seems like a typical problem.
  17. Jun 15, 2012 at 10:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I do alot of leafspring R&R & it seems the difficulty level with removing bolts is relative to the type of climate you live in , I'm in dry ass Socal so as you would imagine I rarely see any bolts or other hardware thats rusted into place
  18. Jun 15, 2012 at 10:37 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    Yeah it definitely does, especially if you live where they salt the roads, but I've come across a bunch of threads with this same problem. I had no problems with any other bolts, very little rust except the exhaust.
  19. Feb 19, 2013 at 12:03 AM
    DoorDing
    DoorDing The game is afoot.
    Sussex Downs
    Hansom cab
    I'm trying to nail down the specs for 2nd gen, greasable rear spring bolts before installing OME Dakars. I know the OEM bolts are 120mm long, but I don't know the other dimensions.
    Will these work with OEM bushings?
    Trail-Gear Bolt Greasable M18 X 120mm
  20. Oct 10, 2014 at 9:12 AM
    danecp05
    danecp05 New Member
    Dane
    Corpus Christi, TX
    2002 Xtra Cab 4X4 V6
    2.5" Pro Comp levelling kit, rear add-a-leaf, 2009 Texas Edition wheels
    Hey everyone, last year I decided to have an add-a-leaf kit installed on my truck. The OEM U-bolts were never returned to me unfortunately which is why I am posting in this forum. I want to remove the add-a-leaf kit because I no longer require them because I do not tow my boat any more (sold it :(). I took the truck to a dealer to have the add-a-leaf kit removed but they were asking approx. $60 to purchase new hardware. The shop at the university I go to has all the sweet machines, tools, and materials that I need to fabricate my own but I do not know the dimensions of the u-bolts. The dimensions I need are as follows,
    - length of bolt
    - width of bolt
    - diameter of bolt
    - curvature of the bolt (if necessary)
    - any other crucial info
    If anyone knows of a website that provides this info that will suffice. I have spent a while searching the web but have only managed to locate info pertaining to the torque specs of the u-bolt.
    Thanks and Gig Em!
    danecp05
