Front left different leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sep1911, Oct 23, 2024.
  1. Oct 23, 2024 at 2:53 PM
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    At 150k my front left axle seal started leaking. Bad enough that there’s droplets at the bottom of the pumpkin. I replaced the seal two times but the leak isn’t even slowing down. The first time around I thought it was me, this second time around I made sure to install it by the book. The seal sits flush and I surgically installed the CV axle into the carrier . I should mention I’m not a rookie with this stuff so this isn’t my first rodeo. Technically the seal has 130k as I previously regeared the truck my self, and put new seals + the ECGS bushing in at the time. It’s been smooth sailing since, until now that is.
    just to rule out the breather I popped the valve off the breather tube so it should be able to breath. No change.
    I regret not taking a photo but I also didn’t think anything of it at the time. . Where the lip of the seal rides on the cv axle, the area was polished to a mirror finish and my nail could catch it.
    So here’s a question, is it possible the area on the CV has worn down enough the seal can’t properly seal? I have never heard of this happening, but my finger nail could catch that surface, so I’m a bit suspicious.
    any thoughts?
  2. Oct 23, 2024 at 3:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Might be caused by rust jacking in the diff case bore. Remove CV axle, remove seal, stuff the diff tube with a plastic bag, then clean up the seal seat area with a flap wheel. Only then install a new seal with some sealant on the OD.
  3. Oct 23, 2024 at 3:18 PM
    Sep1911
    2016 Taco
    Yup that’s gotta be it. I noticed some minor rust but didn’t want to fuck with it too much so I gently ran some scotch brite on it. What kind of sealant do you recommend?
  4. Oct 23, 2024 at 3:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    :notsure: Ultra gray? Right Stuff? The seal seat should be degreased with brake cleaner. You should also hold off refilling the diff until the sealant has cured. So pick a sealant with short curing time for schedule's sake.
  5. Oct 23, 2024 at 3:46 PM
    Sep1911
    2016 Taco
    Gotcha. I thought you meant a pipe dope or something similar. I understand what you mean
  6. Oct 23, 2024 at 3:57 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The groove on the CV shouldn’t catch a nail. If it is, then it probably is too sharp and is wearing out seals. I’d sand it down or replace the CV.
    And maybe I’m misunderstanding, but the seal shouldn’t be installed flush. It should be recessed to a specific depth of something like 0.189”-0.229”
  7. Oct 28, 2024 at 6:40 PM
    Sep1911
    2016 Taco
    after a few of days of running it with the new seal and topping it off everyday the leak stopped. I’m not sure if the new seal needed to bed in, or if me not installing it 0.189-0.228” is allowing the seal to sit in a different spot.
    anywho, I topped the fluid, went on a 400 mile round trip to an off-road event, abused the truck there and there’s still no sign of even a little seepage.
    I’ll take the win, and will continue to monitor.
  8. Oct 28, 2024 at 7:15 PM
    BLtheP
    Plano, TX
    I was mistaken on the spec. The left side should actually be about flush. I could have sworn it followed the same spec as the right side but nope. Good that the leak stopped.
