Front left suspension clicking sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fused_Taco, May 7, 2021.
  1. May 7, 2021 at 2:37 PM
    Fused_Taco
    Fused_Taco [OP] Well-Known Member
    Franco
    Wyoming
    2017 Toyota Tacoma OffRoad
    So I've been having a clicking noise for awhile now and have no clue what it is. I get the noise left front suspension when I hit dips or just anything that really pushes suspension up so can anyone help? I have a video clip of it but it won't load on here for some reason
  2. May 9, 2021 at 8:00 PM
    Ganjafornia
    Ganjafornia Chicks dig the long bed
    Los Angeles, CA
    18 Dbl Cab Trd off road Longbed
    Stock
    Same thing happened to my 18 Offroad 4x4
    Clicking and clacking on dips and speed bumps
    Dealership changed both front shocks and problem solved
    Hope this helps
    Fused_Taco[OP] likes this.
  3. May 9, 2021 at 8:03 PM
    PuckerbuttPliny
    PuckerbuttPliny Well-Known Member
    California
    2018 TRDOR 4X4 DCLB
    275/70r17 KO2 E Load 4R TRD Pro Rims
    Mine has been doing this since I had <5k miles on if, dealership swears they can’t recreate it (even after driving with them and pointing it out).
  4. May 9, 2021 at 8:13 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Stock or is it modded?
    Fused_Taco[OP] and shakerhood like this.
  5. May 9, 2021 at 8:26 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    My 2018 does it too.
  6. May 9, 2021 at 8:38 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Check the torque
    Fused_Taco[OP] and PinStripes like this.
  7. May 9, 2021 at 8:40 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    This. Check the linkage nuts and possibly the mounts. Loose sway bar makes clicks.
    Yotaholic and Fused_Taco[OP] like this.
  8. May 9, 2021 at 10:56 PM
    Fused_Taco
    Franco
    Wyoming
    My truck is stock 2017 offroad 14500 miles
    Lt. Dangle[QUOTED] likes this.
  9. May 9, 2021 at 10:58 PM
    Fused_Taco
    Franco
    Wyoming
    I was going to stop into the dealer cause I did get oil change and rotate then noticed after that.....
  10. May 9, 2021 at 11:48 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Check your wheel torque. If not matched, it could make sounds.
    Torque should be 81ft-lbs
  11. May 9, 2021 at 11:54 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    body mount bushing
    Fused_Taco[OP] and MoneyMan55 like this.
  12. May 10, 2021 at 3:24 AM
    jamestown
    jamestown Well-Known Member
    NB, Canada
    2017 DCLB TRD Sport 4x4 AT Silver Sky M
    Off road wheels Factory HT tri fold tonneau
    Mine has done it as long as i can remember.
    Fused_Taco[OP] and Stoked4 like this.
  13. May 10, 2021 at 3:45 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    My body mount bushing did this. Replaced under warranty
  14. May 10, 2021 at 3:50 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Same^^^
