Front left wheel bearing help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomajeff, Sep 9, 2011.
  1. Sep 9, 2011 at 8:14 PM
    Tacomajeff
    Tacomajeff [OP] Member
    Jeff
    Western NC
    05 Tacoma TRD 4wd
    05 Tacoma 4wd. 112,000 miles
    Front left wheel bearing shot. Have heard new bearing assembly bolts right on. No pressing needed. Is this true? Mechanic wants $400.00. Seems pretty unreasonable to me. Searched and searched the forums. If anyone could point me to the thread if this has already been covered it would be greatly appreciated. Am pretty good DIY guy w/proper guideance.
    Any step by step help out there?
    Thanks.
  2. Sep 9, 2011 at 8:23 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I think the bearings are pressed in/out of the spindle assy. Not bolt on. Check out this video, I didn't watch it, but the comments on the page say nice vid, so I assume it's good.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/176080-diy-front-wheel-bearings.html
    I just typed in wheel bearings and this was on the first page......
  3. Sep 9, 2011 at 8:58 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I just did this. Got the bearing hub assembley off ebay for 40. Did the work myself except pressing out the old hub from bearing hub assembly, shop did for 35 it took like 15 minutes. U need inner and outer seals and o ring. Pretty easy
  4. Sep 9, 2011 at 9:21 PM
    Tacomajeff
    Jeff
    Western NC
    05 Tacoma TRD 4wd
    I understand now. Bearing is not pressed into spindle but hub & bearing are
    pressed together as one unit. Nice video. Should spindle be removed & inner seal be replaced while I am in there. Seems a broken inner seal could let debris into bearing & cause same trouble again. Could be the cause of the current bearing malfunction, although 112,000 is alot of miles on a bearing.
  5. Sep 9, 2011 at 9:41 PM
    NelsonTacoma
    Tucson, AZ
    If you have it apart you might as well replace all the seals. I'm sure the seals only cost a few bucks and since the bearing is rather expensive you definitely want to make last as long as possible.
    I did watch the video after posting it here just to see, and it seems very easy, especially if you have access to air tools.
  6. Sep 10, 2011 at 11:08 AM
    Tacomajeff
    Jeff
    Western NC
    05 Tacoma TRD 4wd
    Thanks to all.
    I think I'll give it a try. I have access to all of the required tools.
    I'll change the inner seal while I am in there too.
    I'll let everyone know how it went. Don't know why my search under wheel bearings came up "no info available." I must be an idiot, I guess.
    Thanks for the link to the video.
  7. Sep 10, 2011 at 12:47 PM
    NelsonTacoma
    Tucson, AZ
    The Internet isn't perfect. Always glad to help. :)
  8. Oct 20, 2011 at 12:28 AM
    Sneeker
    Sneeker Member
    I come from the land of the Ice and Snow
    05 Toyota Tacoma TRD OFF Road
    :eek:Im at the point where i have the stearing joint apart to get at the inner seal and the outer seal(attached to the drive shaft). How hard is it to replace and... What do I do????:eek:
