Front leveling spacer kit.
Discussion in 'Suspension' started by Mytacoma01, Jul 27, 2017.
  1. Jul 27, 2017 at 4:17 AM
    Mytacoma01
    Mytacoma01 [OP] Well-Known Member
    Bob
    Hendersonville NC
    2014 charcoal gray SR5 double cab.
    Hello all, i would like to discuss leveling my front end out after adding an add a leaf to the rear end to decrease the sag of my new camper. I have a generation 1 4x4 and now that the add a leaf is in, the rear end is significantly higher than the front, and I expected that. It did level the truck with the camper hooked up but, now I think I want to level the truck and deal with the sag. I would like to pick the brain of some of you who have installed the leveling spacers to the front shocks.
  2. Jul 27, 2017 at 4:28 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
  3. Jul 27, 2017 at 4:39 AM
    Mytacoma01
    Bob
    Hendersonville NC
    Why do I need pics to discuss an installation of a well know product. I merely want insight on a couple of aspects. I obviously haven't installed the spacers so I cannot provide photos.
    TRD-ED likes this.
  4. Jul 27, 2017 at 4:41 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. Jul 27, 2017 at 5:07 AM
    TRD-ED
    Lenoir NC.
    Pics aren't really needed. And I was referring to a pic of the truck so someone might give insight into just what size spacer lift would be needed.
    A 1/2" spacer doesn't equal 1/2" lift.
    Unchained 5150 likes this.
  6. Jul 27, 2017 at 6:01 AM
    Mytacoma01
    Bob
    Hendersonville NC
    I see well, I guess this is gonna go into why I started this thread. I attempted this install and aborted because, after I had disconnected the upper ball joint, the brake line bracket and the steering knuckle, placed the spacer on top of the shock and installed the shock into the upper mount, I wasn't sure that after bolting the shock to the bottom mount, that I was gonna first of all, be able to raise th axle up high enough to pull the upper ball joint bracket down and bolt it in and then, if I was gonna be able to raise the truck up high enough to get the wheel back on with the jack that I have. By the way, I did see the reply from Clearwater Bill and will read it as well. :)
  7. Jul 27, 2017 at 3:47 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    @Mytacoma01 If there is anything that we can help you out with just let us know :cheers:
    Thank you so much @Clearwater Bill :cheers::cheers:
