Front license plate bracket...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10toy, Nov 9, 2009.
  1. Nov 9, 2009 at 11:19 AM
    10toy
    10toy [OP] Active Member
    OH
    2010 Tacoma 4x4
    So I bought my truck in FL where there is no front plate required...truck did not come with the mounting bracket. Now I live in VT where they require a front plate... :confused:
    Did your trucks come with the bracket? Should it have?
  2. Nov 9, 2009 at 11:22 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Mine didn't, I have it wired right now because I still don't want to have to drill a hole in my 2001 bumper. Sad I know.
  3. Nov 9, 2009 at 11:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    They don't come with one unless it is bought in a state that requires front plates, usually.
  4. Nov 9, 2009 at 11:26 AM
    10toy
    OH
    2010 Tacoma 4x4
    bummer...ok. Thanks!
  5. Nov 9, 2009 at 11:30 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i don't know about our trucks, but i swapped out a plate on my dad's car once and it was just two holes drilled in the plastic with the large threaded screws holding it in. they almost looked like shorter and fatter dreywall screws.
  6. Nov 9, 2009 at 1:48 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    You will see 2 dimples in the bumper, That's where you will drill the holes cuz it's thicker behind and you can use stainless sheet metal screws like I did..
  7. Nov 9, 2009 at 1:50 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    They don't make a 'bracket' for a front plate on our trucks. It sucks. Like others have said, there are two dimples where you screw the plate directly into the bumper.
    I suggest putting some sort of self-adheisive padding on the back of the plate when you screw it in to keep it from scratching the bumper. Of course, putting it on means you're going to have a couple of great big holes in the bumper anyway, so what's another few scratches.
    I had a vanity plate on my front bumper for a while. I got some of that heavy-duty self-adhesive velcro from WalMart and used the soft side to line the back of the plate. When I took it off there were no scratches. I ended up getting a new bumper b/c somebody crashed into me in a parking lot... I didn't put the plate back on b/c I didn't want to re-screw into the bumper.
  8. Nov 9, 2009 at 1:51 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I bought a plastic black license plate holder from wally world for 10 bucks, came with large thread screws and keeps the edges of the plate from scratching the clear coat on the bumper cover. cheap, easy and safe.
  9. Nov 9, 2009 at 1:55 PM
    mws4ua
    Birmingham
    Probably the easiest way to go. Good call.
    I just wish there was a way to put a plate on there w/o doing permanent damage to the bumper.
  10. Nov 9, 2009 at 1:55 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Dealer drilled two holes in my bumper. I removed it and added a couple of plastic washers behind the plate between the plate and the bumper to keep the plate from scratching the bumper. Required to have a front plate in California.:mad:
  11. Nov 9, 2009 at 1:56 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Here in Missouri I got popped with 4% tint and it was $81 but I only had the truck 2 weeks and went to the prosicuting attornys office and told them I removed it right away and they dropped it...
  12. Nov 9, 2009 at 2:11 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    i boought mine in virginia and mine didnt have one dealer drilled two holes in the plastic and called it a day. now i live in north carolina where as i dont need a front plate just have a bs john deer vanity plate on it for now
  13. Nov 9, 2009 at 3:14 PM
    calicoupe
    calicoupe Well-Known Member
    I was looking at the 08 4runners and they mount the plates by using clips that are attached to the lower vents.........
    I am going to see if I can get the part numbers.....just another idea....
  14. Nov 9, 2009 at 4:07 PM
    mws4ua
    Birmingham
    ^^^ Let us know if that works out... but I believe the bumpers are different enough that it won't.
  15. Nov 9, 2009 at 4:10 PM
    jandrews
    '09 FourDubDee TRD OR
    Screw front plates.
  16. Nov 9, 2009 at 5:49 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    yup
  17. Nov 9, 2009 at 6:05 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    I here that man, when I got pulled over couple of weeks ago and was asked about my front plate I told the officer that I had the bracket on order thru Toyota (lie) I ask him what's the purpous of a front plate and his comment was cuz it's the law.. I used to give donations to the state troopers and now when they call for money I am going to tell them that as soon as they look away at the BS laws and tell the young gungho troopers that it's not a big deal I will start giving again and don't tell me to write my congresman cuz they are so full of corruption it's sickening oh f__ket don't get me started on our corrupt judcial and political system..
    Oh yeah the front plate is a bad idea..
  18. Nov 9, 2009 at 10:27 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    yeah mine was screwed in and i think it got riped out during some night offroading in some deep deep puddles and sand dunes :D
    all i know is i woke up next morning and had two holes where i used to have a license plate
  19. Nov 10, 2009 at 2:56 AM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Knowingly that high you still put it on?? The kicker in Missouri is that a tint ticket is a safety violation and $81 a seat belt violation is $25 go figure..
  20. Nov 10, 2009 at 4:36 AM
    Flyguymike
    Flyguymike Member
    S.E. Flordia, USA
    01 PreRunner , Red
    window vents,Westin step bars
    A few years ago I shipped a 4X4 downed to Belize where i spent 6 months building a summer house. I got my insurance sticker to put on the windshield and then went to the " Lands Department " and paid for my tags. ( front & back ) They were out of metal plates so, the teller hand wrote this small but very polite note explaining the matter and stamped it. She explained to me to show it to an officer if I got stopped.
    I had to drive through a Check Point twice a day between where i was renting and to my house site so i got used to whipping out this very used piece of paper. I kept checking in with " Lands" every week and was always told the tags would be in next week. I couldn't call them, I had to go and stand in line for a half an hour.
    After the seventh week I knocked off work at noon one hot Sat. and proceeded to get a little " Nice-Up " at the local bar. On the way home at the Check-Point the guard looks at the front of the vehicle and asked " Where are your front plates ? "
    I replied " It is in the same place as my back plate". He gave me this classical look of
    " WTF ,This stupid Gringo put two plates on the back of his truck?" before he could say anything I showed him my magical paper. Then he had this Big grin on his face and said " You got me good this time man " so I handed him a cold bottle of water, and off I go.
    Anytime I saw him after that he would give me that same big grin and just wavy me through. I did get my plates after 11 visits to " Lands ".
