Front lift 1"?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pltommyo, Apr 16, 2020.
  1. Apr 16, 2020 at 1:31 PM
    pltommyo
    pltommyo [OP] Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I need about 1" lift after putting on bumper and winch, to get leveled back out. I am thinking spacers is fine. Is the lift roughly 2:1? Meaning 1/2" of spacers on top of shock will lift 1" at wheel?
  2. Apr 16, 2020 at 1:35 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    A 1/2 spacer will give 1”.
    2:1 lift will be 2inch lift on the front and 1 inch lift on the rear.
  3. Apr 16, 2020 at 1:38 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Toytec 1/2 spacers. It’ll give you that 1”
    pltommyo[OP] likes this.
  4. Apr 17, 2020 at 7:08 AM
    pltommyo
    Tom
    I keep getting confused on using these. They say "Up to 2" of lift" with the 5100's. Is that "up to 2" of lift" more than my TRDOR or is it "up to 2" of lift" compared to an SR5? My worry with using them is that I would have to set them to the top ring to get a 1" lift on my TRDOR and then have it ride like a brick.
  5. Apr 17, 2020 at 9:53 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    You can put new coils on to correct the height for the added weight.
    Frankenstuff likes this.
  6. Apr 17, 2020 at 10:14 AM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    This is what you need.
    Crikeymike[QUOTED] and DSMHokie like this.
  7. Apr 17, 2020 at 3:28 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Trucks are the same height regardless off the trim.
  8. Apr 18, 2020 at 1:50 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Remember if you change your coils Bilstein's warranty is void. The OME coils are sagging a bit, my friend went through two sets and now back on his org. springs and the ride never really changed. Some people think it helps but I have driven his truck a few times and see no difference between mine and his.
  9. Apr 18, 2020 at 12:29 PM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    I would get some new coils too if you’re digging into things. If you’re heavy enough to compress your springs an inch all the time, you’re sprung too light. Do it right and get something to carry the load properly. Not just raise up your smashed springs.
    Also keep in mind that 1” isn’t just lost height. It’s lost uptravel too meaning you’re that much closer and more likely to bottoming out.
    Crikeymike likes this.
  10. Apr 18, 2020 at 1:51 PM
    Frankenstuff
    Frankie
    I’ve put two sets of ome coils on the front . One for stock weight and some heavies for a full hoop and winch . There’s a difference but mostly in drivability with added weight . You will experience overloaded sag with oem weight coils. Especially under medium to hard braking.
