Front lift but stock in the back?
Discussion in 'Suspension' started by YellowDog01, Feb 10, 2010.
  1. Feb 10, 2010 at 3:48 PM
    YellowDog01
    YellowDog01 [OP] Well-Known Member
    04 4x4
    I did a search, but nothing much came up.
    Has anyone done 2.5-3" of lift in the front and then left it stock in the rear?
    This will probablly level it and then give it some lean.
    Will this allow me either to run 285/76/16 or 255/85/16? Whichever one.
    Thanks. Pictures would be great if anyone has any.
  2. Feb 10, 2010 at 4:07 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The front will sit Higher than the rear with 2.5" of lift up front. If you like the baja racer PreRunner look then thats fine.
  3. Feb 10, 2010 at 4:36 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    yeah what Dan the man said!
  4. Feb 10, 2010 at 4:38 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    yeh mine leaned pretty bad had to add one inch blocks in back, perfect now though
  5. Feb 10, 2010 at 6:17 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I got Toytec coilovers to level the front--then raise up later if I decided to lift the rear w/ AALs. Currently have about 1.5-2" front lift and 265s
  6. Feb 10, 2010 at 6:25 PM
    YellowDog01
    04 4x4
    Tim-is that picture with no lift in the back?
    Dont want MAJOR lean in the back...just want the front a tad bit higher than the back. And if I do AAL then I'll have to get longer shocks...
  7. Feb 10, 2010 at 6:26 PM
    YellowDog01
    04 4x4
    Any pictures before? Thanks
  8. Feb 10, 2010 at 6:30 PM
    Tim A
    Montana
    Rear is completely stock, non TSB springs and 265/70/17 BFG ATs
    If you want to really dial in your lift, I'd suggest coilovers up front.
  9. Feb 10, 2010 at 6:40 PM
    YellowDog01
    04 4x4
    I would love coilovers, but I'm a broke highschooler who just wants his truck to look good. Not going to abuse it and take it off road...Just towing. Thanks
  10. Feb 10, 2010 at 6:53 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    running a 2.5 in up front, and only the tsb springs in the back. front is about 1.25 inches higher than the back, but i kinda like the look. it also stiffened up the ride a little, which i also like. here's a before and after
  11. Feb 10, 2010 at 7:01 PM
    YellowDog01
    04 4x4
    Whats Tsb springs? Is that stock? I love the look of that!
  12. Feb 10, 2010 at 7:08 PM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    3 inch toytec, magnaflow exhaust, KNN intake, URD MAF, HID 55 watt, Hella 500 HID, Smoked tail lights LED running lights, Pioneer deck with 8 inch infinity sub, Focal 165VB and 165CVX with JL 320/4, Tinted all around 3%, Tinted interior lights.
    3 inch lift and stock in the rear. I have 265/65/16
  13. Feb 10, 2010 at 7:11 PM
    YellowDog01
    04 4x4
    Sweet Kyle. I have a 2001 Double cab so with around 2.5" in the front and wheel spacers ill be able to fit 285s?
  14. Feb 10, 2010 at 7:14 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    TSB = technical service bulliten. for the 05+ tacomas there is a heavier duty set of springs you can get from toyota to replace the weak stock ones it ads +/- about 1 inch to the rear.
  15. Feb 10, 2010 at 7:17 PM
    YellowDog01
    04 4x4
    Im a 1st gen dummy. haha.
    I love my 1st gen. though.
    Im thinking 2.5" in the front/stock rear and 285s
  16. Feb 10, 2010 at 7:17 PM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    I think so my buddy has a 2000 extra cab tacoma and he has a 2.5" lift and he put 33/12.50/R15 which is a little bigger than 285 and it looks sick!! I think your truck will look bad ass for sure.
  17. Feb 10, 2010 at 7:36 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    1st gen taco is whole other ballgame from the 2nd gen...
    3" front lift on a 1st gen dcab will set you pretty nose high with a stock rear...
    you will be able to fit 285-75-16s with 4" of wheel backspace...
    for the rear, make sure you go with a long AAL if you go that route...
    you can also look into shackles, but they will wear the stock leafs very quickly...
    you will need longer rear shocks if you do lift it... you want to get into an 8.5" travel rear shock...
    what kind of budget are you working with to do the lift?
  18. Feb 10, 2010 at 7:38 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    2.5" on a dcab and 2.5" on a reg or xcab are not the same height with the 1st gens...
  19. Feb 10, 2010 at 7:43 PM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    Pretty damn close it will still hold the 285's for him though
  20. Feb 10, 2010 at 7:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i have had my 01 dcab for 9 years now... i tried it on mine and a couple other 1st gen dcabs over the years...
    its close, but the noise of the inner sidewalls rubbing on the frame on turns and articulation gets annoying...
    of course, he could always blast his radio and he won't notice the noise...
    :headbang:
