Front lift height before you blow through CV Boots
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jwmac, Feb 13, 2018.
  1. Feb 13, 2018 at 1:00 PM
    jwmac
    jwmac [OP] Well-Known Member
    I had an 04 tacoma that had an adjustable coilvover lift. Around 2.5" of front lift and the CV boots started eating themselves.
    I now have a 2017 DCOR that I am planning to bring the front up an inch or so in order to level it out with the stock rear. It looks like the angles are pretty much the same on these 3rd gens compared to the 1st gens.
    However, I am curious at which point do the CV fins on these 3rd gen trucks start contacting and blowing out? Seeing as how dealers appear to be installing 3/2 lifts like crazy it seems that the angles must not be that bad or do dealers just have no problem with replacing boots every 6months on there dime?
  2. Feb 13, 2018 at 1:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The general consensus is up to 3" and you're good as far as CV angles go. They will wear faster, but you won't be blowing through them every 6 moths.
  3. Feb 19, 2018 at 11:49 AM
    jwmac
    Thanks, anybody with a 1-3inch front lift have any first hand input?
  4. Feb 19, 2018 at 11:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Me. I have a 3” lift up front and have 3rd gen friends with the same and the same applies.
  5. Feb 19, 2018 at 11:55 AM
    jwmac
    How much room do you have between inner boot fins? They have to be pretty darn close?
  6. Feb 19, 2018 at 11:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They will touch at that height. They’ll wear faster, but nothing crazy where you’re replacing every 6 months. If you don’t want them to touch, you can cut the outer clip off and slide them farther out, and secure with a hose clamp.
