Front lift question
Discussion in 'Suspension' started by rogerkamp8817, Apr 20, 2010.
  1. Apr 20, 2010 at 12:10 PM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    I got the rear TSB done and I would like to level the front out. I'm thinking about getting Bilstein 5100's.
    Can I save some change and re-use my factory TRD off road springs? Is this not recommended? What is the spring rate of the factory spring compared to after-market springs (ie OME).
    I'm planning on running factory wheels and tires for a while so I don't think I'm interested in a 3 in lift (don't want it to look tiny). I mostly off road in the desert, with lots of wash board stuff that rattles my teeth out. I'm looking to get better ride quality in this kind of environment.
    thank you!
  2. Apr 20, 2010 at 12:19 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The 5100s are designed to re-use your factory coils. Which is a great way to go. For what you are doing, you may want to get the bilstein 5100s both front and rear, and get the 3 leaf aal set for the rear. That will really help with wash boards.
  3. Apr 21, 2010 at 12:10 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Yo Roger! Yeah, you'll be happy with the 5100s and stock coils for leveling and improved ride.
    On a side note: air-down your tires off road! Set your tires (let the air out) to about 25psi on the washboard and you'll be amazed at how much smoother your ride is. Plus 25psi is plenty safe to drive on the street with untill you can find some air at a gas station or buy a $25 air compressor powered off your cig-lighter. Buy a decent tire gauge too, somethng in the $15+ range.
    Even for casual offroading I'll go to 25psi and for the gnarly stuff I go in the 12 to 20 range depending on the terrain.
    Let me know if you want to wheel on Sat, I'll show you the ropes of the tire world.
  4. Apr 21, 2010 at 12:14 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I've found that the OME shocks handle heat build-up from washboarding and lots of bumps way better than the bilsteins from my 'wheeling experiences. I like my OME's way better than the 5100's for the money. Just my $.02
  5. Apr 21, 2010 at 12:36 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    You will be surprised what billy 5100s with the factory coils can do, my avatar pic is with billstien 5100 at 2.5 with stock spring and 3 leaf aal. yea like the guy above said air out your tires and it will completely change the ride.
  6. Apr 21, 2010 at 8:43 AM
    rogerkamp8817
    awesome! I placed an order for the 5100's. can't wait for them to get here.
    John, I think I'm heading up to Pyramid on Saturday in the afternoon to do some fishing. We can go up a couple hours early (noonish maybe) and try out some stuff of those trails if you're down!
