front lift??
Discussion in '4 Cylinder' started by jaytrain, Oct 13, 2010.
  1. Oct 13, 2010 at 7:49 PM
    jaytrain
    jaytrain [OP] Member
    Jackson
    Durango,Co
    1997 Tacoma
    Built a cold air intake,flowmaster 40 series
    I was wondering which front lift is better to go with, a front coil spring or a front spacer??? Also which is better for the driving geometry of the truck?
  2. Oct 13, 2010 at 7:57 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Adjustable coilovers or larger coilovers are probably the best methods. What's available for your truck depends upon if you have a 5-lug or 6-lug truck. Spacers are available for both types of tacomas. They are not the best way to level, but are way cheaper to purchase. If you decide to go with a spacer, avoid the kind that mount in the coil assembly. The top plate spacer is the better of the two types of spacers IMO.
