front loader washer question
Discussion in 'Garage / Workshop' started by coffeesnob, Jul 17, 2010.
  1. Jul 17, 2010 at 6:53 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Hope someone can help. We have a front loader samsung washer and dryer. It's about two years old a few months ago the little cup that you put fabic softner into fills up with water about halfway after doing a load. Also if you put softner into it it doesn't get sucked out. The detergent side is right beside it and it works just fine. Any ideas? Thanks
  2. Jul 17, 2010 at 6:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Try to take it apart and clean it out?? Sound like it's just clogged....
  3. Jul 17, 2010 at 8:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't have a samsung. I have a Whirlpool Neptune....So, not sure I can help you or not.
    Are you sure the fluids get 'sucked' out of the cups? With mine...I have to fill the cup up with softener to a 'fill line'. The water pours in there and the mixture of water/fluid flows over the top of the cup. There is no 'sucking' action. On mine, if you remove the cup....there is no holes in the bottom. If you don't fill the fluid up to the 'fill line', it doesn't work properly and leaves water/fluid left behind after the load is done.
    This website is frigin awesome for finding some answers to appliance problems.
    http://applianceguru.com/
  4. Jul 17, 2010 at 9:43 AM
    coffeesnob
    VA
    No, not sure if the fluids get sucked out. What you say though makes sense that water gets added to softner and then pours out, but even so, there is ALWAYS water in the cup that never used to be there when the machine was brand new and when I do put softner in it after the load is done it still looks milky so I don't know if any at all is going in the tub or not.
  5. Jul 17, 2010 at 10:16 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Those dispensers use a siphon action to dispense softner and bleach. If you manually pour water into the dispenser where you put your bleach or softner, you will see what I am talking about. Insufficient water flow to that cup in the dispenser will cause what you are describing.
    Possible causes: Low water flow from house water supply, bad water valve inside machine, clogged passages in the dispenser itself. There may also be a mechanical linkage that switches the dispenser into different modes.
    Take the hoses off the back of the machine and look for debris caught in the filter screens in the machine's water inlet valves. Also check the house end of the hoses for any filter screens that may be installed there. Be very careful not to get any debris in the machine valve while cleaning the screens.
    Pull the dispenser drawer out and look for the water passages located on the roof of the dispenser compartment. If anything looks clogged, try to clean with a paperclip.
    If you can get the machine's top panel off, check for any obvious broken mechanical parts on the dispenser linkage.
    This problem usually results in the dispenser assembly getting replaced. The small passages inside the dispenser get clogged up from hard water.
  6. Jul 17, 2010 at 11:49 AM
    coffeesnob
    VA
    i'll check the hoses, the dispenser drawer is not clogged ,thanks
