Front locker before rear locker?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A7XT, Mar 10, 2010.
  1. Mar 10, 2010 at 1:25 PM
    A7XT
    A7XT [OP] Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    Maybe I am just naive and inexperienced, but does this idea have any merit? Say you have a TRD sport with LSD rear diff and only can afford one ARB air locker to get more serious with your wheelin. Would leaving the LSD in the rear diff and installing the locker in the front diff make more sense than replacing the rear LSD with a locker? I mean the front has more weight over it for more traction and you can steer to gain traction with two locked tires. Any ideas?
  2. Mar 10, 2010 at 1:28 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    As long as you know how to use it, it shouldn't be a problem.
    Abusing it WILL break your diff or a CV
  3. Mar 10, 2010 at 1:37 PM
    4cyl4x4
    4cyl4x4 Active Member
    East
    07 4x4x4
    I too agree with your logics, it sounds solid.
  4. Mar 10, 2010 at 1:37 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    if your truck is an 09 like it says in your profile, you dont have an lsd rear... but i was actually thinking of going the same route..ish, and putting a detroit auto-locker in the rear and an arb up front.
  5. Mar 10, 2010 at 3:02 PM
    A7XT
    Kyle
    WYOMING
    I thought 09 had an LSD....what does it have if not an LSD?
  6. Mar 10, 2010 at 3:04 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    it has auto LSD
  7. Mar 10, 2010 at 3:05 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    it has auto-lsd. it uses brake pressure to slow the slipping wheel. it only works in 2 wheel drive when you hit the vsc shutoff switch... search the forums there a ton of in depth explanations on how it works.
  8. Mar 10, 2010 at 3:05 PM
    drew02a
    San Antonio, TX
    Auto LSD? I thought they had LSD too, but I just checked the specs on the Toyota website.
    They at least have Auto LSD, but that's all brake actuated.
  9. Mar 10, 2010 at 3:10 PM
    rmb_crew
    09 has auto LSD only. Works with ABS to brake the slipping wheel while transfering power to the other wheel.
  10. Mar 10, 2010 at 4:01 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    It also has front and rear "Auto Lsd" in 4 high, it's just called TRAC in Toyota speak. And the brakes transfer torque when applied, not just slow the spinning wheel......
  11. Mar 10, 2010 at 4:19 PM
    Isthatahemi
    TRD OFF ROAD
    Do the 4L TRAC mod, and you will have the best of both worlds. Limited slip at both ends with none of the steering / breakage drawbacks of lockers. Less capability, yes. But more capabilty than most would ever use.
    http://www.tacomaworld.com/forum/technical-chat/51946-4low-trac.html
  12. Mar 10, 2010 at 4:42 PM
    A7XT
    Kyle
    WYOMING
    thanks for the help! will this mod work on a TRD sport too?
  13. Mar 10, 2010 at 4:54 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Tag...
    A front locker would be helpful in getting the front wheels up rocks/vertical obstacles. Plus I like my rear LSD for hauling ass in the desert.
  14. Mar 10, 2010 at 4:59 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    how's that auto LSD working for you now? if it's working fine on the trails that you are doing then i'd say get the front locker. but if you're out on the trails and cursing at your LSD because it's just not enough to get over whatever obstacles then i'd say get the rear locker first
  15. Mar 10, 2010 at 5:21 PM
    A7XT
    Kyle
    WYOMING
    I have never had a problem on dry trails so far, but I have been stuck many times in deep snow where the one wheel in the front and rear with no traction will spin and the ones that may have traction just sit there....wish I would have gotten the offroad with the elocker. Any idea if this 4L atrac mod will fix this problem?
  16. Mar 10, 2010 at 5:47 PM
    Isthatahemi
    TRD OFF ROAD
    It is not ATRAC. It is TRAC (4 wheel limited slip), working in 4L. And it is amazing. I now have a truck with ATRAC, and this mod is 80% of ATRAC's abilities. With this mod, all 4 wheels spin together, none of that 1 front, 1 rear wheel spinning garbage.
  17. Mar 10, 2010 at 5:50 PM
    A7XT
    Kyle
    WYOMING
    Thats frickin sweet thanks!! I am gonna try it tomorrow. It will work with a TRD Sport right? I dont have an ATRAC button but I have the button that shuts off VSC....
  18. Mar 10, 2010 at 5:54 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    if u have ATRAC, u wouldnt need the yellow wire mod.
    if it hasnt been stated already, you have an open rear diff and i would put a locker in the rear (cuz thats what i will eventually do)
  19. Mar 10, 2010 at 6:07 PM
    Isthatahemi
    TRD OFF ROAD
    Yes it will work. And the VSC button will de-activate it when pushed. Prepare to be amazed, as this mod is vastly superior to having just a rear locker, and about $1G cheaper too.
  20. Mar 10, 2010 at 6:22 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    TRAC is great! Do the wire mod that Hemi speaks of and have it in L4, too (for those with Sport TRDs). The Off Road TRDs get A-TRAC in L4... even stronger than TRAC...
