Front Locker: Is it worth it?
Discussion in 'Off-Roading & Trails' started by LoadedTaco, Apr 2, 2014.
Do you have a locker and have you used it.
  1. No
    50 vote(s)
    53.8%
  2. Yes, used it 0 times
    4 vote(s)
    4.3%
  3. Yes, used it a few times
    15 vote(s)
    16.1%
  4. Yes, I have used it and needed it many times.
    24 vote(s)
    25.8%
  1. Aug 6, 2014 at 1:17 PM
    #61
    LoadedTaco
    LoadedTaco [OP] Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    So it has been a while since I got my gears installed and my front locker hooked up. Let me tell you right now it is absolutely, 100% worth re-gearing* and getting a front locker**.
    *IMO Re-gearing only worth the cash it if you run 35s+
    **IMO Front Locker Only Worth the cash if you wheel hard
    Using both lockers on the Hells Gate
    http://youtu.be/jM1P9BZkmVk?list=UU-Vd74niqE29d9t1k6uD_zQ
    Lateralus likes this.
  2. Aug 6, 2014 at 3:29 PM
    #62
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Silly duratracs need all the traction they can get :D
  3. Aug 6, 2014 at 3:32 PM
    #63
    Large
    Large Red
    :laugh:
    FWIW, I've wheeled pretty hard and only used the front locker a handful of times, most of which I could have just used skinny pedal to get where I wanted to go.
  4. Aug 6, 2014 at 3:35 PM
    #64
    Manwithoutaplan
    ID
    how is your Mpgs these days poopie?
  5. Aug 6, 2014 at 4:53 PM
    #65
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Very nice. I need to do Moab again...
  6. Aug 11, 2014 at 10:04 AM
    #66
    SIZZLE
    SIZZLE Well-Known Member
    Novato, NoCal
    2014 DCSB TRD Off Road
    Take off this, move that, don't need this...
    After watching this, YOU definitely need the front locker! I wouldn't attempt that hill climb without one.
  7. Aug 11, 2014 at 12:13 PM
    #67
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Not hating on Pete, but several people (including myself) have run the Gate open/open. Just sayin. If you can keep all the wheels on the ground, there is plenty of traction, its is when you lift a wheel that the locker really comes into play.
  8. Aug 11, 2014 at 10:01 PM
    #68
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    This May be true but I can take you on trails open open would never make. I don't give a rats azz how many tires you have on the ground..
  9. Aug 12, 2014 at 7:54 PM
    #69
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I don't think my next set of tires will be duratracs. They are not a bad tire, but there is better options.
    Roof rack hurt it, the gears helped a little. I am hovering right around an average of 14.
    Nah I used it because it was new and I had it. There are plenty of people who have run it open/open. Mike or mh.meier's girl friend did it in his truck last year Open/Open
    Proof (Skip to 0:50 if you don't want to see how you get into hells gate)
    http://youtu.be/497WNkvfu_Q?list=PLsZH5tu4m9c-A7QiSi_yejyEjKo-nXs7J
    ^This.
    I had all four on the ground at the begging and was spinning tires. If I was open I would have had to back down and use more momentum or a new line.
  10. Aug 12, 2014 at 7:56 PM
    #70
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD
    Lots of dust and custom dents, Check Build
    I've heard a lot of people tell James this...
  11. Aug 13, 2014 at 12:21 AM
    #71
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
  12. Aug 13, 2014 at 6:05 AM
    #72
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Damn I thought you would be getting better than that. Hell I get 14 :eek:
  13. Aug 13, 2014 at 6:30 AM
    #73
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Question for those who have actually done this: Can a 4 cyl with manual trans, 4.56 gears, and 33s make it up without too much clutch riding?
  14. Aug 13, 2014 at 6:41 AM
    #74
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    No. the clamshell case means it'll basically explode the front diff on the gen 2. in a solid axle.. Yes. worth every penny.
  15. Aug 13, 2014 at 6:50 AM
    #75
    BamaToy1997
    Bill
    Navarre, FL
    How you figure? I see a lot of video of IFS trucks doing that without breaking.
  16. Aug 13, 2014 at 8:52 AM
    #76
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I wasn't making a blanket statement, just about the Gate specifically. I plan to regear and add lockers this winter, and I can't wait to see what it opens up for me! I will add that learning the capability of your truck without lockers is probably the best way to go, and then adding them after you have basically maxed out your driving skills and unlocked truck's capability. Also, see below. :D
    LOL, very true.
  17. Aug 13, 2014 at 8:58 AM
    #77
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 Old Man Tan 4runner, EAF Mother Licker
    Says the cheater with a-trac. :p
  18. Aug 13, 2014 at 11:45 AM
    #78
    Smoke
    Eastern Ontario
    2006 SR5
    The clamshell will deflect and prematurely wear out your gears at best on 32s. On 37s in actual rock crawling it'll be enough to grenade the front end.
  19. Aug 13, 2014 at 12:47 PM
    #79
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    Got it.... no worries.
  20. Aug 13, 2014 at 2:46 PM
    #80
    slander
    slander Well-Known Member
    Bolingbrook, Il
    02 Tacoma, fixed with curse words.
    I have needed it many times, but didnt have one so ive used the winch as my front locker. I want to get one, however its easier to pull winch cable than fix broken CVs which will now be a constant worry. So i keep flip flopping back and forth.
