Front Locker options on a 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jazz1one, Oct 13, 2015.
  1. Oct 13, 2015 at 10:30 AM
    Jazz1one
    Jazz1one [OP] It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    I see a lot of posts talking about how great the arb air locker is. I'd like to hear from people who have a front e-locker. And anyone with a front arb? Pros cons..
    I want to keep the LSD system in place and just wondering what my best option for a front locker is. Definitely want it to be selectable. After that, I don't know what I want..:help:
  2. Oct 13, 2015 at 10:31 AM
    Jazz1one
    Calgary AB
    Great! Why? Why not an e-locker? Do you have a front arb?
  3. Oct 13, 2015 at 12:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    front and rear diffs on the trd sport are open diffs.... any "LSD" is simulated through braking of the slipping tire. Throw a locker in the rear before throwing one in the front.
  4. Oct 13, 2015 at 12:38 PM
    Jazz1one
    Calgary AB
    You know this for sure? Dealer said it was mechanical..
  5. Oct 13, 2015 at 12:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Early 2nd gens had a mechanical one in the sport. Your 2015 is electronically simulated.
  6. Oct 13, 2015 at 1:26 PM
    nd4spdbh
    SoCal
    everything after 2008 (so 2009+) has the brake simulated LSD and an open diff.
  7. Oct 13, 2015 at 2:06 PM
    Jazz1one
    Calgary AB
    Ok. So adding a rear locker won't interfere with that fake LSD?
    And why do the rear rather than front if I'm just doing one for now?
  8. Oct 13, 2015 at 3:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    When locked both tires will turn at the exact same speed so the electronic LSD would not engage.
    The majority of your traction from tackling obstacles/hills comes from the rear. If you are in a situation where you need the extra traction to justify the locker, you want the traction out back where it will be most useful. Also locking the front will make steering much more difficult when locked.
    You can do a wiring mod to add a simulated LSD to your front diff, like is used in the rear, for increased front traction.
  9. Oct 13, 2015 at 3:25 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Is this legit info? Seems like most of the weight would be on the front wheels so wouldnt those provide better traction?
  10. Oct 13, 2015 at 3:26 PM
    Jazz1one
    Calgary AB
    That sounds inexpensive :) I'm listening..
  11. Oct 13, 2015 at 3:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Usually when using a locker you are trying to get over/up something, meaning the vehicle is inclined and the weight balance has shifted toward the rear. It is not often one uses a locker on flat ground (unless in mud) or a decline. It could be argued I suppose that you would want to put it up front because you are more likely to lose traction up front with limited IFS travel and reduced weight when attempting to climb and obstacle. Every OEM manufacture puts the locker in the rear.
    It is free. It is known as the 'yellow wire mod'. It basically acts like a less aggressive version of A-TRAC.
  12. Oct 13, 2015 at 3:52 PM
    Sep1911
    2016 Taco
    Good info, thanks. I always like having informative discussions like this.
  13. Oct 13, 2015 at 3:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
