Front Locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by arctic04trd, Oct 17, 2017.
  1. Oct 18, 2017 at 11:04 PM
    #41
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    For sale on FB
  2. Oct 21, 2017 at 9:46 PM
    #42
    arctic04trd
    arctic04trd [OP] VA7XTE
    British Columbia
    2010 DCLB
    I appreciate all the responses guys. I've decided to go ahead with a locker and the regear. I will continue to mod/un-mod this truck until I'm happy with its state or I need a land cruiser lol.
    Thanks for the opinions. It was really informative. I'll keep you posted and I'll post a thread on the 4.88s and ARB once I've run them for a reasonable period. I find that most of this info is on ttora and yotatech. I realize this forum is less wheeling oriented (as am I) but I still think that it's part of the love for modding these awesome trucks.
    One last word; get out and find new adventures. For a lot of us, we are not living until we experience new places, suffer breakdowns, and let those experiences shape our character. :canada:
  3. Oct 22, 2017 at 12:06 AM
    #43
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Just regeared to 4.88's with ARB lockers front and back. Got some miles of breaking in before I can give my 2 cents but I'll keep you posted.
  4. Oct 22, 2017 at 9:28 AM
    #44
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Tim, I really appreciate the time you spent making your excellent videos. I've made a few machining videos and they can take fair amount of time.
    I have a question for you or anyone else. I plan in the future to install an elocker in the front of my Tacoma. If I were to remove the sway bar, steering rack and the drive shaft flange from the diff before removal, could this be a one man job? I figure I could support the front diff with a scissor diff jack that I have.
    I was able to remove and install the front diff on a 89 Toyota truck but it had a 4" bracket lift which gave all kinds of room.
  5. Oct 22, 2017 at 9:38 AM
    #45
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    If you’re asking if it’s possible to drop the front diff solo the answer is yes. It’ll take around 4 hours. I was able to do it with just a floor jack. It’s definitely not a cake walk. Some of the hoses on top are very hard to get to and the diff just barely slides in and out around the x members and what not. You’ll need to be pretty able-bodied.
    btu44[QUOTED] likes this.
  6. Oct 22, 2017 at 9:59 AM
    #46
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    Also I had a fox mid travel setup when I had the ARB locker. To help me from blowing up even more CVs than I did, I got limit straps so that the CVs would not hit such hard angles which caused them to break easier.
    Ritchie likes this.
  7. Oct 22, 2017 at 2:39 PM
    #47
    btu44
    Long Beach area, Ca
    Yea, it looks like a major PITA. But considering this job is close to $1000 (my guess) in labor with locker install it's worth the hassle and cursing.
  8. Oct 22, 2017 at 8:58 PM
    #48
    Timmah!
    Timmah! Well-Known Member
    TIM
    I don't think you need to remove the sway bar, steering rack or the drive shaft flange. I pulled the front diff on a friend's 3rd Gen 4runner to replace the clam shell for one from East Coast Gear Supply that had an ARB locker installed. It was definitely a pain in the ass to get out and back in. But, since then, I learned a tip from one of the subscribers of our YouTube channel. The guy disconnected the driver side motor mount and jacked up the engine to get more clearance. The problem with getting the diff out and back in has to do with the rear mount design. It has a stud that sticks down into the cross member. To get the diff out, you have to jack up high enough so the stud clears the cross member but then you have issue of the diff flange hitting the bell housing as you're trying to get it out. When we did the job, we disconnected the transmission mount and jacked up under the transmission to gain a little more clearance but we didn't mess with driver side motor mount. I think if you disconnected the driver side motor mount and the transmission mount, got a jack with a block of wood under the oil pan and jacked up the engine, you'd have the clearance necessary to make the removal and reinstallation way easier.
    Now, with all that said, that differential is freaking heavy and awkward. You might be able to do it yourself but there's a certain amount of muscling that needs to happen that a jack won't be able to help you with. I think you'd be better off if you could get a friend or family member to help you if possible. When you watch the video, you will see the struggle Fred and I were having with that monster.
    I have two videos for you. The first is for the Front Differential Replacement and the second is for dealing with the Motor Mounts and Transmission Mounts.
    https://www.youtube.com/embed/w_gPiDvh9v4
    https://www.youtube.com/embed/g_4DiywsSbk
  9. Oct 23, 2017 at 8:49 PM
    #49
    btu44
    Long Beach area, Ca
    Yes, 2 good videos. The trans mount vid made my own mount replacement a half hour job.
    I do agree it is a 2 man job to remove the differential. Laying on my back with that much awkward weight over head is a good way to get hurt.
  10. Oct 23, 2017 at 9:25 PM
    #50
    Timmah!
    TIM
    If you lived closer, I'd say come over my place and I'd help you out but you're in Southern California and I'm in Northern California.
  11. Oct 23, 2017 at 10:46 PM
    #51
    36tacundra
    36tacundra Well-Known Member
    words to live by, 3 things not to lend out. never loan out a pen, your truck, or your wife. no matter what, because you never get them back the same way.
  12. Oct 23, 2017 at 10:58 PM
    #52
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    +1
  13. Oct 23, 2017 at 11:03 PM
    #53
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Definitely not. Helical gear LSD instead and here is one of many sources that explain why.
    http://www.fourwheeler.com/how-to/transmission-drivetrain/131-0606-front-locking-differentials/
  14. Oct 27, 2017 at 7:36 PM
    #54
    arctic04trd
    British Columbia
    2010 DCLB
    I've read the article. Fourwheeler is talking about rigs on 40s and wheeling on rocks. Neither of these apply to my application. And I don't believe that even a stock 7.5" tacoma ifs will handle the abuse that these guys run their rigs through.
    I do take their article to heart, but I just don't see the relevance to my situation. Thanks for the insight though
  15. Oct 27, 2017 at 7:40 PM
    #55
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm the opposite, I'll let anyone drive it, I'll encourage hooning off-road and I've taught a few to drive stick in it haha. I'd love to see the look on a valets face if I told them to park it, my clutch is dump truck level stiff ever since I swapped it.
    Also OP @drr is right eliminating front spider gears is wise if money is no option, ARB is a great idea.
    drr and arctic04trd[OP] like this.
  16. Oct 27, 2017 at 7:43 PM
    #56
    arctic04trd
    British Columbia
    2010 DCLB
    FIFY
    Money is an object, but I've made the decision that I don't want a new truck. Which opens up funds to mods haha
    Ritchie and Speedytech7[QUOTED] like this.
  17. Oct 27, 2017 at 7:46 PM
    #57
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I've seriously considered locking my Tacoma but came to the exact opposite conclusion you did. I don't rock crawl either so feel like there isn't any need a front locker. LSD is more than adequate for my uses without the risk of a locked IFS. My Jeep is another story. I rock crawl and wheel hard with that and the front is sporting a D44 Currie Rockjock with an ARB locker.
  18. Oct 27, 2017 at 7:46 PM
    #58
    Speedytech7
    Good decision!
  19. Oct 27, 2017 at 7:56 PM
    #59
    arctic04trd
    British Columbia
    2010 DCLB
    Ok. Point taken. I agree a locker is for harder trails than a gravel FSR. But there are different types of terrain. My terrain is deep snow, muddy trails, icy snow, loose rocks, slushy snow, and occasionally hard packed snow. Lots and lots of snow. I've found the e-locker gets me further than open-open, so I'm assuming the front will help even more. And I'm trying harder and harder trails even in the summertime without rock crawling. Since rock crawling doesn't really exist in the PNW
  20. Oct 27, 2017 at 8:02 PM
    #60
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You mean "muddy roots and slippery bullshit crawling" lol.
    Front locker helps a ton in the snow, especially the selectable part of it. Need to steer? Unlock it. Need to smash through 6 ft of Cascade concrete? Lock it up.
