Front main seal leaking??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Nov 18, 2010.
  1. Nov 18, 2010 at 4:50 PM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Well I think my front main seal is leaking. The bottom of my engine is covered in oil and it only happens when the truck is running. Never once have it left a spot of oil on the ground. Nor is it bad enough to make the level drop on the dip stick (which I check weekly after discovering this). The leak appears to be coming from the front main seal as opposed to an of the oil lines. I have yet to pull off the crank pulley and check under that.
    I was just wondering if anyone else has ever heard of this problem??
  2. Nov 18, 2010 at 4:56 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    does it look like this
  3. Nov 18, 2010 at 5:05 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Not nearly that bad.. I just have a light film of oil that occassionally forms a drop if I dont clean it off for more than a week.
  4. Nov 18, 2010 at 5:07 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea just had my leak fixed it was a crackcase gasket.....
    if you had pics of exactly where it is forming it would be better
  5. Nov 18, 2010 at 5:13 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I was looking around on here, it seems like the timing cover is a place known to develop leaks
    I just have a light film basically everywhere but it seems to start around the front main/crank seal, so thats my best guess for now
  6. Nov 18, 2010 at 5:15 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea i thought it was mine also but i cleaned it up real nice with engine cleaner and then you could see it
  7. Nov 18, 2010 at 5:26 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    i had my front timing cover seal start leaking. It would leak at the bottom left corner very light then it got a little bad over time. Dealer wanted $1500 to fix it i bought oem toyota parts and fixed it for $90.
  8. Nov 18, 2010 at 5:41 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yup thats what i would have done if it wasnt warrentied...
    i got more leaks than a subamarine on mine:cool:
  9. Nov 19, 2010 at 10:09 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I replaced my front engine oil seal (crank seal) myself about 2 months ago. The seal was around $20 and can be done in a few hours. I made a pulley holder from a piece of flat stock. Tried using the ratchet strap/chain to the frame method without luck. Loosened the bolt by bumping the starter with the breaker bar against the frame.
    Mully and ABNFDC like this.
  10. Nov 19, 2010 at 10:27 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, thats the ticket !!! :D:D
    ABNFDC likes this.
  11. Dec 5, 2010 at 12:55 PM
    lightnin
    lightnin Member
    jeff
    west palm beach
    05' 4x4
    33'" tires
    just replaced the front main on my 05 there are other posts on here about the pulley causing the oil leak somehow. it rubs a grove into the metal or something. i cant find it now.
  12. Dec 5, 2010 at 1:02 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :eek::canada:
  13. Dec 5, 2010 at 2:59 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I forgot about this thread.. well they replaced the main seal and reinstalled my stock pulley.
    Ans then the leak started again... turns out the stock pulley wasn't creating a good seal either and it needs to be replaced too. Good news is that the dealer is replacing the seal again without charging me any labor. I only have to pay for the new pulley ($300 but it could be worse)
  14. Jul 28, 2017 at 4:12 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    THREAD RESURRECTION!!!
    Hey man im pretty sure my crank shaft seal just shit the bed as well. So you are telling me i need a new pulley AND the crank seal?
    ManBeast and BassAckwards like this.
  15. Mar 4, 2020 at 4:15 PM
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    So, anyone confirm this??
  16. Mar 4, 2020 at 11:08 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    If pully is grooved see if they have sleeve kit for that size seal .Something like this.
  17. Mar 25, 2020 at 2:20 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Does this look like it is the front main? Found it while replacing my idler pulleys.
  18. Mar 25, 2020 at 2:37 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Timing chain cover is also possible
  19. Mar 25, 2020 at 2:53 PM
    08TRDOFFROAD
    Dan
    I hope not. I will have to look and see how high up the oil staining goes. Crossing my fingers it's not the cover...don't have the money to fix it and don't feel like it is something I could tackle on my own.
  20. Mar 26, 2020 at 6:58 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I understand, now is not a great time for repairs. It looks like it will be ok for awhile just keep an eye on your oil level. There are videos on just about everything lots of other good resources to if you decided to do the job just be meticulous about organization put everything in bags label it take tons of pictures do everything you can to help yourself.
    Mully likes this.
