Front mud flaps with big tires.. help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elevatedfun, Aug 15, 2010.
  1. Aug 15, 2010 at 1:16 PM
    elevatedfun
    elevatedfun [OP] Well-Known Member
    Austin
    Idaho
    BSP 07 SR5 doublecab 4x4
    33" nitto terra grapplers, 3" readylift, 17" ultra goliath wheels, TRD seat covers, Huskey floor matts, Flowmaster 40 series muffler, OBX fatboy shift knob, K&N high-flow cleanable airfilter, Pioneer AVH-P4200DVD, Lamin-X yellow fog light covers, Ultragauge
    I have 33" tires and i have found they throw gravel and rocks up into the side of my truck from the front. Its not getting popped up from the outside of the fender flares as much as it is that little gap where the lower body cuts in. My tires are too big (even with the 3" lift) to fit stock front mud flaps to cut down on the rocks getting kicked up. I am thinking of having a welder cut out 2 mud flaps for me out of diamond plate, does anyone have any other suggestions or has anyone had a similar issue but found a great way to fix it? Thanks!
  2. Oct 31, 2010 at 9:25 AM
    sch0enne
    sch0enne Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    Bump! i would love a solution for front flaps with bigger tires also
  3. Nov 1, 2010 at 2:41 PM
    elevatedfun
    Austin
    Idaho
    Since this post I did some thinking of my own and bought a sheet of 1/8" diamond plate. I then traced out a small front mud flat, had a welder burn them out for right and left, and drill holes in them that matched up with the factory holes in the flares. Then i had him put a slight bend in them to get even more clearance when turning my tire (cause steel plate being ripped off and bouncing around off my tire, suspension, and body didn't seem appealing).
    I am working on putting them on this week actually, if you would like I will post a picture with the final product
  4. Nov 1, 2010 at 2:43 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    :worthless:
  5. Nov 1, 2010 at 5:31 PM
    sch0enne
    03 Tacoma TRD
    Put these on yesterday. A thin material but extremely durable. I made a thread about them yesterday, someone else said they will never hold up on the trail but I am more than confident with them.
