Front Mud Flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, May 26, 2009.
  1. May 26, 2009 at 4:41 PM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    Anyone else seem to think the front flaps are a touch to large? :eek: Don't get me wrong, they work great at their job. I don't want to run no flap, b/c I have a new white truck and attract tar on all my vehicles. I was thinking about trimming a few inches off, or buying some shorter ones and selling the OEM's. Opinions?
  2. May 26, 2009 at 5:07 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    This was the first thing I noticed that I didn't like about my Taco. Also--If you get a chance on the highway, take a look at someone else's taco in the lane next to you. You'll see that the front flaps sail really bad at speeds above 60 MPG. Can you imagine the wind drag??
    I took mine off and cut about 3 inches off from the bottom with a jigsaw and rounded the corners best I could. I like them much better now. Glad you mentioned this. Nice post. I don't think anyone here has brought this up yet.
  3. May 26, 2009 at 5:12 PM
    FL4x4Taco
    Yes I have noticed that!!! I see that all the time, and am thinking... "are mine doing that?" lol. I also was thinking about the wind drap MPG issue!! These front flaps looks huge. You have any pics with your 3" trimmed off?
  4. May 26, 2009 at 5:15 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    here's a pic of my old 07 w/ the front and rear flaps cut 3-4". about the best pic i have to see from a distance. definately look better shorter and more practical too.
  5. May 26, 2009 at 5:19 PM
    FL4x4Taco
    Nice. I think I might just trim the front ones 3" and call it good. cheapest/easiest thing to do. Thanks for the pics/discussion guys. I'll take pics before/after too.
    By the way... new to this forum, and so far I'm loving it!! must say, good forum.
  6. May 26, 2009 at 5:22 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2008 double cab, 4X4, V-6, TRD. Super White.
    OME 885 coils & front shocks, with TT top plate, Total Chaos UCA, Rear OME extended shocks, Rear TSB, Rear Toytec AAL, trimmed the saber-tooth-tiger-long-ass mud flaps. 17" XD Revolver rims, 265/75/17 BFG AT KO's. Ripped out the crappy FM Modulator & installed a PA-15-toy interface. OEM bed matt.
    Welcome to TW!
    Personally I think you should take them off. And beings you will have them off, sell them to me relativley cheap:D
  7. May 26, 2009 at 5:23 PM
    jhodge83
    SC
    when i did mine, all i used was a good pair of tin shears and a small box cutter. i drew on the first flap w/ a pencil and then used the cut off piece as a stencil for the other 3 flaps. just be careful of the plastic pop ins when removing the flaps
  8. May 26, 2009 at 7:50 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Just trim them on the truck. It's easy.
  9. May 27, 2009 at 5:22 PM
    FL4x4Taco
    Yes, planning on trimming them on the truck. Lots of room. I'll be using a good pair of sheet metal sheers; ex commercial framing snips. round the corners, use some sand paper to remove any burs and blend it back in.... should work out pretty well. I'm gonna start with 2" up front and do 1/2" incriments from there. Thanks for the opportunity to talk about it and bounce ideas around. Like I said, I'll take some pics.
  10. May 27, 2009 at 5:35 PM
    jhodge83
    SC
    if you chose to trim the rear as well, they are much thicker and harder than the fronts.
  11. May 27, 2009 at 5:54 PM
    FL4x4Taco
    Good to know. As of right now I think I will only trim the front ones 2-3". Go from there.
  12. May 27, 2009 at 6:03 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    i hate thes flaps...the other day i accidently slid into a ditch on a dirt road, i wasnt messing around. i was about 2" from sitting my passanger side on the ground. the flaps were totaly in the mud and i was hoping they would be ripped off.(my neighbor with the biggest 4 wheel dodge ram and mud tires towed me out luckley)
    but they do serve a good purpose and do their job for onroad use
  13. May 27, 2009 at 6:04 PM
    EBruddah
    EBruddah Well-Known Member
    626 - SGV / RakiRaki, Fiji
    05 TRD Off Road 4X4 - OME Built to Wheel!
    2005 Tacoma V6 SR5 - 4WD AC TRD Off Road - 6 Speed M/T Full OME Lift w/886 Coils & Dakars,, Optima Yellow Top, Cobra NightWatch 29 WX NW ST - CB Peaked/Tuned + talkback/confirmation tone - PA Horn, Lil Will CB Antenna, Downey Off Road Extreme Duty CV Boots, 255/85/R16 BFG Mud-Terrain T/A KM, All-Pro Sliders, Drop in K&N FilterCharger, Flowmaster 40 Series, 62” Hi-Lift Extreme Mounted in Bed w/all Hi-Lift Accessories. Custom Skid Plate by Defined Engineering, 10 lb. PowerTank with HPX Regulator
    I lost my mud flaps 2 months into owning my truck.... If you wheel it they'll self-clearance! Trust me!
  14. May 27, 2009 at 6:48 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I'd like to see pics when you're finished FL4x4Taco. I've been thinking about trimming the front flaps on mine too. I want to make a cardboard template based off the lower radiused part of the flap, then move that up to the desired cut off location, secure the cardboard template with tape, and then cut the flap.
  15. May 27, 2009 at 8:01 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I really wanted to keep mine on to protect my new white paint... but they eventually drove me nuts when offroad because they drag on everything and make a horrible noise. I just took them off completely, it looks ok but even the smallest bit of mud will shoot up and make the "taco rainbow" across your doors. Last weekend I followed my buddy through a 100' section of muddy trail, I had to roll up my windows and by the time it was over it loked like I had just spent the entire day mudding; my buddys Taco still has the front flaps on, the only things muddy were the wheel-wells and the wheels, it was otherwise totally clean... the flaps definitely work well at protecting the truck. You shouls just trim them if you want to protect the paint.
  16. May 28, 2009 at 4:58 AM
    FL4x4Taco
    Exactly, I want some protection. That's why I'll be doing 2-3" of trimming.
  17. Jun 9, 2009 at 7:07 AM
    carmellocafe
    KEVIN
    N. California
    Here's a couple of pics... I only cut the fronts. It doesn't seem the rear flaps bend from wind sheer. The're made a lot stiffer than the fronts so I left them alone.
  18. Dec 16, 2009 at 5:32 AM
    Accokeekian
    Accokeekian New Member
    Southern Maryland
    08 SR5 4 door
    Billet Grille Chrome Nerf bars Hood protector Rain guards
    I have 08 tacoma with no fender flares and seems to be problem finding aftermarket front mud flaps, any ideas?
  19. Dec 16, 2009 at 11:06 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sell the OEMs and buy a set of Powerflow Pro Fit mudflaps, you'll come out ahead
