Front mudflap trim successful!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huckyourmeat, Nov 2, 2010.
  1. Nov 2, 2010 at 8:43 PM
    huckyourmeat
    huckyourmeat [OP] Well-Known Member
    Denver, CO
    10 TRD OR DC Silver
    Finally got up the courage to trim my front mudflaps. I was a little nervous, but I took my time and used the tin snips method others have talked about. Made sure the truck was level, measured the height of the rear flaps, marked that height on the front, then cut straight across, same height on both right and left (duh).
    After cutting straight across, I took the piece that I trimmed off and traced the curves onto the mudflap. Since the cut flap is a little wider due to the taper, I traced one side, then slid the "template" over, and traced the other side.
    Before re-installing, I decided to add Clearbra where the flaps touch the fender flares. This took a while, but if you've done any clearbra before, this wasn't too tough. Hardest part is the trial and error of getting it cut right, but after you get one cut, you can use it as a template for all four flaps (rear needs to be slightly larger, so I used it as my template). I've only had my truck for about a month and a half, so I wanted to do that as soon as possible to make sure that there wasn't any fender wear due to time.
    Tools that came in handy:
    --Tin snips-straight cut, left cut, and right cut. Helps with the curves.
    --Files-double bastard (Aggressive) and flat-cut (smoother). Helps to grind down the serrations from the tinsnips and remove the little flaps that form from re-positioning the snips. Obviously start rough, then go smooth (that's what she said).
    --Sandpaper/foam sanding blocks-80 grit through 400 grit. 400 grit really helps "polish" the edges so that they look factory. Same as above...work your way to the higher grit.
    Here are some pics...let me know what you think or if you have any questions! I'm very pleased with the results and really glad I did it.
    Trimmed flaps:
    Clearbra:
  2. Nov 2, 2010 at 9:04 PM
    TacoSupreme
    TacoSupreme Well-Known Member
    Cuatro Por Cuatro
    Looks good
  3. Nov 2, 2010 at 9:17 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I also did this mod as soon as i got my truck, what a waste of time tho! As soon as you upgrade tire sizes (which you will soon enough, if you spend any amount of time on this site) you'll need to remove them anyways.
    Looks good tho, and the clearbra was a nice touch...
  4. Nov 2, 2010 at 9:24 PM
    BWro
    BWro Well-Known Member
    I trimmed the front rudders off my truck soon after i replaced the tires. Looks good
  5. Nov 3, 2010 at 3:30 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Did you remove the mud flaps from the truck to cut them? If so, how hard is it?
  6. Nov 3, 2010 at 4:53 AM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    :)subd, Looks great! I want to know if there is any less protection to the side of the vehicle with them being shorter. Let us know what you notice. Want to trim mine, but afraid I'll then be throwing crap up the side of my truck that escapes under where i trimmed.
  7. Nov 3, 2010 at 7:31 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Thats probably the cleanest trim job i remember seeing on those.
    Nice work.
  8. Nov 3, 2010 at 8:43 AM
    BWro
    I think i trimmed off 3 or 4 inches, and it still protects thr sides. No chips and its been about a year
  9. Nov 3, 2010 at 9:35 AM
    Motorshooter
    Motorshooter Motorshooter
    VA-Northern VA
    16 double cab, short bed, 4X4 SR5, Towing pkg. Inferno Orange -What a great color!
    Weather Tech stone guards, Undercover SE bed cover, Rhino running boards, modded N-Fab light bar with two Hella 7" Driving lights, 2 Ridged cube fogs, fresh coat of wax. I really miss my Indigo Ink Pearl 07' DC -RIP-she saved my life. Thank you blue beast!
    Looks great!:D
  10. Nov 3, 2010 at 2:46 PM
    huckyourmeat
    Denver, CO
    10 TRD OR DC Silver
    Thanks for all the compliments, guys. Like I said, it wasn't as hard as I expected and it turned out better than I thought it would.
    I'll let you know if I notice any more "stuff" flying up, but looking at them, it's hard to imagine the physics of something flying up and making it past the mud guard. They still look like they'll protect pretty well.
    I did remove the flaps. The main reason I did was for the Clearbra, but if I had to do it again, I would take them off even if I wasn't doing the Clearbra. Removing the flaps is quite easy--it's just three 10mm bolts (which also have phillips head inside, but you'd have to have a pretty short screwdriver to get at them since the tire is in the way).
    After that, there are three of the press-fit retainer clips. Slip a small flathead screwdriver under the inner flange part, wiggle your way around, then pry it up gently. Once the inner part pops up, all you do is grab it and gently wiggle and the whole clip slides out.
    Really, it is quite easy to remove the mudflaps and it definitely made marking, cutting, filing, and sanding much, much easier.
  11. Nov 4, 2010 at 9:23 AM
    huckyourmeat
    Denver, CO
    10 TRD OR DC Silver
    Funny experience...I was in the parking lot of Home Depot this morning and when I came out, there was a Tacoma that had parked next to me. The driver asked me where I got my mudflaps!
    He only had one on the front and ripped one off wheeling up by Blackhawk. Told him I cut them, sent him to Tacoma World. Hope to see him here!
  12. Nov 4, 2010 at 9:30 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Where's the How-To write up.
  13. Nov 4, 2010 at 11:56 AM
    huckyourmeat
    Denver, CO
    10 TRD OR DC Silver
    Sorry, only had a short time to do it so I didn't have time to take pics of the process. All of the details that I followed are in my posts, though!
