Front off road bumpers under 60lbs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco600mpg, Jan 10, 2021.
  1. Jan 10, 2021 at 2:57 PM
    Taco600mpg
    Taco600mpg [OP] Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
    R there any front off road bumpers that r under 60 pounds
  2. Jan 10, 2021 at 7:27 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    No
    why under 60lbs? Even an aluminum bumper is going to be around 75-80
    CygnusX191 and Alexely999 like this.
  3. Jan 11, 2021 at 6:31 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    IMO, a lighter bumper will not withstand true offroad impacts. Steel>aluminum>OEM.
    Doubt you will find an aftermarket aluminum under 60lbs and if you do, it's likely will not provide full front end coverage.
  4. Jan 11, 2021 at 7:17 AM
    Taco600mpg
    Cam
    Cuse my brush guard is 60 pounds and it doesn’t hurt my mpg or ride hight
  5. Jan 11, 2021 at 7:21 AM
    Taco600mpg
    Cam
    I don’t plan on taking it in places where I need one, it’s really just for looks and won’t get damaged like my plastic bumper did from rubbing against a guard rail in
  6. Jan 11, 2021 at 7:22 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Rubbing against the guardrail will most likely damage and aluminum bumper.
  7. Jan 11, 2021 at 7:27 AM
    Taco600mpg
    Cam
    Yes but u could probably fix it, with the plastic u got to buy a new one
  8. Jan 11, 2021 at 7:32 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    wi_taco and CygnusX191 like this.
  9. Jan 11, 2021 at 7:32 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Not really, aluminum gets brittle the more you bend and shape it. You might be able to pull it out a little bit after that first hit, but you'd be better off learning how to drive better than be worried about trying to bend bumpers back in the shape when you hit things. Imo
    stickyTaco, JMcFly and outxider like this.
  10. Jan 11, 2021 at 7:52 AM
    Taco600mpg
    Cam
  11. Jan 11, 2021 at 7:56 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    most off-road bumpers weigh around 110 lb. You can get heavier ones but clearly you don't want that lol. If it's not listed on a manufacturer's website, a quick email or message usually gets results. Most manufacturers are pretty friendly and easy to work with.
  12. Jan 11, 2021 at 7:59 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    I used to have one. I'd guess that it's around 40 lbs, probably a bit less. Worth reaching out to Avid if you want a more accurate figure.
    outxider and CygnusX191 like this.
  13. Jan 11, 2021 at 8:29 AM
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    Well then you may want to keep your "brush guard" then. If you're in it just for the looks you gotta go commit or quit.
    my bare US Offroad winch mount is I believe 70lbs without the winch and around 120 with the winch. Thats as light as I can go before getting a full metal bumper which I honestly wont do for a long time and when I do I'll probably get the big ole ARB bumper
  14. Jan 11, 2021 at 8:34 AM
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    R U serious? :)
  15. Jan 11, 2021 at 8:40 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    i believe my aluminum pelfrey is 60lbs or less. but obviously not available anymore
  16. Jan 11, 2021 at 8:52 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The ARB one is around 170-180.... It's also the only one (I believe) actually crash tested and designed to work with airbags and such. So they have that going for them.
  17. Jan 11, 2021 at 10:14 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Allpro aluminum is 58lbs
  18. Jan 11, 2021 at 11:11 AM
    Taco600mpg
    Cam
    yup
  19. Jan 11, 2021 at 11:12 AM
    Taco600mpg
    Cam
    U got a link?
  20. Jan 11, 2021 at 11:16 AM
    Oreo Cat
