Front output shaft leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Durango Bob, Oct 21, 2016.
  1. Oct 21, 2016 at 11:27 AM
    Durango Bob
    Durango Bob [OP] Well-Known Member
    Mat-Su, Alaska
    2009 4.0 Extended Cab
    Dumb leveling kit
    Have a slow drip off the front output shaft of my transfer case.
    Pickup is a stock 2002 Taco, 3.4 liter, 5 speed. 160k miles.
    It started about a year ago after driving about 100 miles in 4 wheel drive on snow packed roads. I've had it repaired 3 times since t began.
    1st time the shop replaced with non-factory seals
    2nd time they used factory seals.
    3rd time factory seals and a new t-case flange.
    3rd time I got it back I couldn't engage my 4x4 at all, but it turned out to be a blown fuse and is possibly not related at all.
    The shop won't cover anything else under warranty at this point because they are claiming "other parts are malfunctioning or that I drive in 4x4 when not necessary". They say I need to take it to the dealership.
    My 4 wheel drive works great and engages immediately. I only use 4 wheel drive when necessary and the past leak started without me ever engaging 4x4.
    What other parts might need to be replaced that are resulting in blow seals in a few days?
    I myself changed front output shaft seals on two dodge 2500s with no issues, so I am wondering if it is just incompetence at the Meineke I was forced to take my truck into.
  2. Oct 21, 2016 at 11:34 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Is the breather breathing freely?
  3. Oct 21, 2016 at 12:17 PM
    Durango Bob
    Mat-Su, Alaska
    Dumb leveling kit
    Thanks cruiserguy.
    If I remember correctly from first looking into this, there is a closed circulation breather on the top of the transmission (top image). And an open breather running from near the front drivshaft input and out under the hood. (Middle and bottom image)
  4. Oct 21, 2016 at 12:17 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    My front Tcase's front seal failed as well awhile back.
    No reason/vent was not restricted... just 15 years old I'll guess.
    Was easy to replace IMO...
    (I purchased a new toyota factory seal, was hand pressed (Thought I used a socket to seat).
    Hasn't leaked since the replacement seal was installed. (8-9 months sf)
    It did however require that I remove the front driveshaft from the Tcase's output.
    So be sure to index mark exactly how the driveshaft is assembled
    so that it is reassembled in phase.
    ^ technically reinstalling the driveshaft exactly how it was originally.
    Including the DS's slip shaft alignment (if taken apart).
  5. Oct 21, 2016 at 12:35 PM
    Durango Bob
    Mat-Su, Alaska
    Dumb leveling kit
    IMG_2977.jpg Thanks Taco Dell. Those are the same steps for replacing it on the dodges my
    Brother and I used to have. After the third failed attempt by the shop I finally had a place to wrench on it myself. Problem was the bolts are so tight on the front drive shaft that they are stripping on me. Using a socket on the nut and wrench on the bolt I can't budge them. Definitely didn't have that issue even working on much bigger diesel trucks.
  6. Oct 21, 2016 at 1:38 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I remember mine being purdy tight as well...
    I think Locktite (red likely) was used..
    You could always try applying some heat to those bolts
    to break the Locktite loose.
    Never stripped the bolt heads on mine.
    You sure yer using the correctly sized wrench ?
    Don't use a crescent wrench...
    rounds them out most every time.
    closed box end wrench instead.
    Of course if you've already stripped those bolt/nut heads...
    even a box end wrench may not hold.
  7. Oct 21, 2016 at 3:13 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Forget the bolts, they are splined and pressed into the flange like a wheel lug. Get a longer ratchet/cheater and put all your effort into your nuts:rofl: then slide the DS off the remaining studs (collapsing the slip joint).
    As far as the leak I can't think of anything other than the breather or bad install.
  8. Oct 21, 2016 at 5:49 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    good point... I guess it's been so long... I forgot that.
  9. Oct 27, 2016 at 2:50 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    just replaced mine a few months ago. Not hard once you get the DS removed. You may need to unscrew and remove the zerk fitting to allow some of the grease in the slip yoke to come out and make compressing the DS easier. It's a 30mm keyed nut on the output shaft and you have to bend/ cut out the keyed part to loosen. On the output flange, I double nutted two studs so I could use a breaker bar resting against the TC and across the flange to make loosening/tightening easier. remove the old seal and tap in the new one. coat with grease and button up. Mine had been oozing for about 4 years and then finally a small river.
